[Qgis-developer] Build Problems on win32
Rob McCulley
RMcCulley at county24.com
Wed Apr 2 17:31:17 EDT 2008
Hi All,
I'm trying to build qgis and the python bindings on Windows XP using
MSVC 7.1 (2003 .NET) using the instructions found here:
http://wiki.qgis.org/qgiswiki/BuildingFromSource#head-696307823157d4af8d
dd12c81acdbea284576a5f
CMake doesn't report any errors at all. This is the output from running
cmake ..:
E:\Build\Source\qgis-svn\Build>"C:\Program Files\CMake
2.4\bin\cmake.exe" ..
-- Found Proj: E:/Build/Source/proj-4.6.0/src/proj_i.lib
-- Found GEOS: E:/Build/Source/geos-svn/source/geos_i.lib
-- Found GDAL: C:/Program Files/GDAL/lib/gdal_i.lib
-- Found PostgreSQL:
E:/Build/Source/postgresql-8.2.3/src/interfaces/libpq/Release/libpq.lib
-- Found Expat: E:/Build/Source/Expat 2.0.1/Bin/libexpat.lib
-- Using GSL from
-- Python libraries found
-- Python bindings enabled
-- Found Qt-Version 4.3.4
-- Configuring done
-- Generating done
-- Build files have been written to: E:/Build/Source/qgis-svn/Build
When I open the resulting .sln file, and build ALL_BUILD, I get a whole
bunch of warnings like:
E:\Build\Source\geos-svn\source\headers\geos\platform.h(34): warning
C4005: '_USE_MATH_DEFINES' : macro redefinition
E:\Build\Source\geos-svn\source\headers\geos\io\WKBWriter.h(110):
warning C4800: 'int' : forcing value to bool 'true' or 'false'
(performance warning)
I also get numerous errors during the core build:
E:\Build\Source\qgis-svn\src\core\spatialindex\storagemanager\DiskStorag
eManager.cc(125): error C3861: 'access': identifier not found, even with
argument-dependent lookup
eManager.cc(147): error C3861: 'open': identifier not found, even with
eManager.cc(189): error C3861: 'read': identifier not found, even with
eManager.cc(250): error C3861: 'close': identifier not found, even with
eManager.cc(283): error C3861: 'write': identifier not found, even with
eManager.cc(317): error C3861: '_commit': identifier not found, even
with argument-dependent lookup
eManager.cc(340): error C3861: 'lseek': identifier not found, even with
Later in the build process, I get a bunch of errors about failing to
find qgis_core.lib, but I assume that it is because qgis_core.lib failed
to build due to the errors above. I'm obviously missing something here,
any ideas what?
Thanks,
Rob McCulley
GIS Coordinator
County of Vermilion River
(780) 846-2244
www.vermilion-river.ab.ca <http://www.vermilion-river.ab.ca/>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080402/e9d61ee1/attachment-0001.html
