[Qgis-developer] Re: EPSG:2180 not recognised, although present
in srs.db
Richard Duivenvoorde
rdmailings at duif.net
Wed Apr 9 15:48:40 EDT 2008
Hi Maciej and others
if you are right, and there is concensus about removing the trailings
zero's from the k/scalefactor, what would be the easiest way to do this?
Some possibilities I see:
- either write a small python procedure (just because I know there is
some sqllite lib for python) which does some string-stuff with the
parameter values in the tbl_srs table.
seems doable for me...
- (re)use the script that initially was used to build srs.db
If it excists, anybody has knowledge of this script?
- do some editing by hand
uhm, volunteers ;-)?
So my question:
1) SHOULD we remove the trailing zero's from the k-factors?
2) I think the python way is the easiest way to go, but if somebody has
the initial script laying around, please sent it to me...
Thanks,
Maciej Sieczka wrote:
> Maciej Sieczka pisze:
>> this gives 1328 out of 6442 SRS definitions incompatible between QGIS
>> and GDAL > 1.4.2 [3].
> Correction - 1157 SRSs.
>> [3]grep "\+k\=.*0" /usr/local/share/proj/epsg
> This should be:
> grep '\+k=[[:digit:]]\.[[:digit:]]*0' /usr/local/share/proj/epsg
> Maciek
> Qgis-developer mailing list
