[Qgis-developer] Re: [Qgis-user] Building image pyramids -> qgis
crashing
Frank Warmerdam
warmerdam at pobox.com
Sun Apr 13 15:16:51 EDT 2008
Oleg Gusev wrote:
> Am Sonntag 13 April 2008 20:53:11 schrieb Maciej Sieczka:
>> Here Frank talks about gdalwarp and "-co COMPRESS" interaction issues,
>> leading to compression under-performance. How does it relate to QGIS
>> crashing when GDAL function for creating overviews is called, as
>> described in Trac [1]?
> "under-performance" is a real under-statement here. gdalwarp (and
> gdaladdo) often segfault when used with "-co COMPRESS" option.
> Both programs use libtiff to write compressed data into an existing
> tiff file, so they fail at the same place.
Oleg,
I am interested in bug reports on GDAL 1.5.1 with libtiff 3.9 CVS head
or libtiff 4 CVS head crashing when creating compressed overviews.
There are known to be problems with older versions, but I believe the current
release GDAL using the internal libtiff (or the cvs head of the 3.9 or 4
branches) run error free.
If you can't assure that a sufficiently recent libtiff will be used, I
would strongly advise against building compressed overviews. In fact,
I'm generally not super keen on them.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
