[Qgis-developer] RFC vector data providers handling
Jürgen E. Fischer jef at norbit.de
Tue Apr 22 13:37:09 EDT 2008
Hi Godofredo,
On Tue, 22. Apr 2008 at 15:57:10 +0000, godofredo contreras wrote:
> Yes, I also think that  notation should be private to the provider.
> This way we can add new types easier without touching any other
> code(OGR case).
Or every other provider.
> > In the process QgsDbSourceSelect should be renamed to QgsSourceSelect.
> > The gui should list should list the registered vector data providers (classes).
> I was thinking a little about this and I think we can unify raster,
> vector (file based) and vector(database based) and even wfs and wms in
> a dialog. This way we can simplify a lot the gui.
I just thought (and cared) about vector layers yet, but your right.
QgsProviderRegistery doesn't make a difference there.  We can take it to
the QgsMapLayer level.
> > Each data provider should have a private list of connections (ie. database
> > connection in PostgreSQL, datasources in OGR) and offer class methods to
> > - list connections by name,
> > - remove a connection by name,
> > - add and edit new connections (this would include a provider specific gui),
> > - return a list of datasource with the available vector layers through a named
> >   connection (ie. layers in OGR, geometry columns in PostgreSQL).  To support
> >   provider specific grouping (eg. for schemas in the PostgreSQL provider) that
> >   could be aggregated in a QDomNod.
> Have you thought about the layer creation? should it be included in
> provider?
> How will we access the new functionality in the provider? do the
> interface needs to be extended?
Above is as good as a list of methods I'd like to add to the providers.
I intended to add class methods.  But we could also add and export
functions (or wrappers for the class methods;  similar to
fileVectorFilters()).
QGISEXTERN QStringList getConnections();
// would return a of registered connection names in the driver
// QgsSourceSelect would call it to fill the connection combobox after
// the provider is selected. This should also get an "New..." entry.
QGISEXTERN bool editConnection(QString connection);
// would be tied to the add/edit button and add/edit a selected
// connection in the combobox and open a provider specific dialog box.
// That gui could optionally include and "Add Layer..." button to create
// a new layer (ie. QgsGeomTypeDialog for OGR, but not tied to just
// shapes).
QGISEXTERN bool removeConnection(QString connection);
// would be tied to the remove button to remove the connection
QGISEXTERN QDomNode *getLayerList(QString connection);
// would be tied to the list layers button (to replace "Connect")
// and return a list of layers that is used to fill QgsSourceSelect
// lists layer list.
QGISEXTERN QgsMapLayer *getLayer(const QDomNode *);
// would instantiate a QgsMapLayer with a selected layer
And the vector data providers might need and additional method to fire
up a gui to set a filter (ie. QgsPgQueryBuilder for the postgres
provider and something similar for OGR layers that support it).
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
