[Qgis-developer] Building universal binary on Leopard for Tiger
William Kyngesburye woklist at kyngchaos.com
Sat Apr 26 21:06:57 EDT 2008
On Apr 26, 2008, at 7:33 PM, Gary Sherman wrote:
> I assume there must be something in the main method that pull in the
> IOKit headers, but I don't know why it fails.
More likely some from Qt.  Which version are you using?
Also, I assume you are using Xcode 3.0?  Probably not hte problem in
this case, but there a couple issues with Xcode 3.0.  You could try
Xcode 3.1 beta - it's in the iPhone SDK.
And, one odd bit in the universal SDK is that even though it adds a
symlink to /usr/local/lib, it doesn't add one to /usr/local/include.
And certainly not /usr/local/qgis_universal_deps/*, and that may cause
other include processing anomalies.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
