[Qgis-developer] Building universal binary on Leopard for Tiger
William Kyngesburye
woklist at kyngchaos.com
Wed Apr 30 00:06:54 EDT 2008
On Apr 29, 2008, at 10:57 PM, Gary Sherman wrote:
> On Apr 29, 2008, at 7:37 PM, Tom Elwertowski wrote:
>> This appears to be a CMake bug in the root CMakeLists.txt caused by
>> FIND_LIBRARY(APP_SERVICES_LIBRARY ApplicationServices).
>> If you add the prefix /Developer/SDKs/MacOSX10.4u.sdk to the path
>> APP_SERVICES_LIBRARY:FILEPATH=/System/Library/Frameworks/
>> ApplicationServices.framework
>> in CMakeCache.txt, the IOKit header errors go away. CMake adds the
>> path to CXX_FLAGS using -F; this seems to turn the boot /System/
>> Library into another directory to search before the -sysroot paths.
> By adding the prefix do you mean the line should look like:
> APP_SERVICES_LIBRARY:FILEPATH=/Developer/SDKs/MacOSX10.4u.sdk/System/
> Library/Frameworks/ApplicationServices.framework
> or ??
Ack! This may seem logical, but that's what the -isysroot flag
(CMAKE_OSX_SYSROOT) takes care of behind the scenes. You may just end
up with GCC looking for headers in /Developer/SDKs/MacOSX10.4u.sdk/
Developer/SDKs/MacOSX10.4u.sdk/System/Library/Frameworks/
ApplicationServices.framework/Headers, and still fail.
> -gary
So, did the symlink for /usr/local/qgis_universal_deps in the SDK not
help?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
