[Qgis-developer] [SoC] beta release of Home Range plugin for QGIS
Tim Sutton
tim at linfiniti.com
Fri Aug 1 04:28:32 EDT 2008
Hi
2008/8/1 Anne Ghisla <a.ghisla at studenti.uninsubria.it>:
> For the moment you can find a sample dataset here:
> http://www.faunalia.it/animov/scripts/sample.csv
Great. I'll fetch it. The svn url you gave seems to for the top level
dir (including hooks etc) - was that intentional? I guess its just the
'prova' dir that needs to go into the plugins folder?
> I'll provide a on-board dataset in the near future, together with a little tutorial.
Great.
> (why, why windows doesn't use slashes as separators? portability is a _headache_!!)
Since you have Qt4 at your fingertips look at QDir::separator() which
will give the correct string for the OS separator. There is also a
call on QDir::nativeSeparators(QString) which will convert a path to
the platform native separator format. Both are static calls so you
dont need an instance first.
Regards
Tim
>> I'll give some more feedback when I have tried it out!
> I'm sure that, with present revision, on Windows systems the plugin can't find
> the R scripts needed for analysis. I'll solve it next week. Let me know if on
> Mac there are similar problems.
> many thanks!
>> Regards
>> Tim
> regards,
> Anne
>> 2008/7/29 Anne Ghisla <a.ghisla at studenti.uninsubria.it>:
>> > Hi all, and apologies for cross-posting,
>> > the code of my Summer of Code project is ready for beta testing!
>> > It's a Python plugin for QGIS that estimates home ranges with different
>> > algorithms, calling R behind the scenes.
>> > Here is the repository:
>> > svn://home.prea.net/svn/GSoC/
>> > ďťż
>> > and here the information page (have a look at system requirements)
>> > http://wiki.qgis.org/qgiswiki/GSoC2008Rbinding
>> > in the repo there is a folder named 'pluginProva'.
>> > Download it in the QGIS user plugin folder:
>> > (qgis_prefix)/share/qgis/python/plugins
>> > run QGIS (better from a shell, control info and some error messages are
>> > still not shown in the GUI) and load the new plugin via Plugin Manager.
>> > That's all.
>> > The plugin needs radio-tracking data, i.e. points. A generic point layer
>> > is accepted; there must be a column that contains the same value for
>> > groups of at least 5 points.
>> > About requirements, I'll be glad if you test the plugin without Numeric
>> > and with different version of all software involved.
>> > Mac testing is particularly welcome.
>> > I'll be glad if you document any running configuration different from
>> > the one indicated in the wiki page.
>> > Before releasing the 1.0 version, I have to find a suitable name for the
>> > plugin.
>> > My first idea is 'homerangeR', but is already the name of another
>> > program (in different case: it's spelled HomeRanger).
>> > http://nhsbig.inhs.uiuc.edu/home_range/ranger_readme.html#9
>> > May I use homerangeR anyway? any suggestions?
>> > Feedback is welcome!
>> > kind regards,
>> > _______________________________________________
>> > Soc mailing list
>> > Soc at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/soc
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton
>> QGIS Project Steering Committee Member - Release Manager
>> Visit http://qgis.org for a great open source GIS
>> Blog: http://tim.linfiniti.com
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
Tim Sutton
Skype: timlinux
