Re [Qgis-developer] Planning for QGIS 1.0.0 '????
Jürgen E. Fischer jef at norbit.de
Mon Aug 4 09:56:23 EDT 2008
[Cc trimmed to list]
Hi Marco,
On Mon, 04. Aug 2008 at 13:51:59 +0200, Hugentobler  Marco wrote:
> So in short: Yes, this check is needed. QGIS won't crash if it is not
> there, but user might be confused when doing a split that creates a
> cut edge.
Thanks for the clarification.
> It might be best to query GEOSversion to see if getCutEdges is
> supported. The bug that arises if the call isn't done is not critical
> and will be outdated after some time.
I think that will generate link errors.  I'd prefer to simply use the
preprocessor symbols.
> I think it will be good to let the geos c-api patch be tested by other
> developers for let's say one week before applying it to trunk. I'm
> going to give you feedback once I did some tests with it.
Ok.  I already ran the geometry tests and intended to extend them to
identify each bug found.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
