[Qgis-developer] Keeping track of API changes for 1.0
Albert Cervera Areny albert at sedifa.com
Thu Aug 7 05:11:48 EDT 2008
A Dijous 07 Agost 2008, Tim Sutton va escriure:
> Hi Folks
> Since 1.0 will be the start of API stable 1.x.x releases I am fixing
> various inconsistencies in the API now while we have the chance. This
> in some cases may require adapting existing code (I've been keeping
> trunk current to my changes). I created a summary (which I will add to
> as needed) of the key areas of change in case you are doing any head
> scratching. I put it in the visual changelog for 1.0 (ok I know its
> not very visual...) :
> http://wiki.qgis.org/qgiswiki/VisualChangeLog1.0.0
Shouldn't "XML" in functions such as "writeXML" be named "writeXml" for
consistency with Qt 4 naming?
> Regards
