[Qgis-developer] r9042 fails to build due to dxf2shp_converter
Maciej Sieczka tutey at o2.pl
Sun Aug 10 03:47:16 EDT 2008
QGIS r9042 fails to build due to errors in dxf2shp_converter plugin.
Details below:
> [ 97%] Generating ui_dxf2shpconvertergui.h
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.ui: An invalid icon property 'windowIcon' was encountered.
> [ 97%] Generating moc_dxf2shpconverter.cxx
> [ 98%] Generating moc_dxf2shpconvertergui.cxx
> [ 98%] Generating moc_builder.cxx
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/builder.h:0: Warning: No relevant classes found. No output generated.
> [ 98%] Generating moc_getInsertions.cxx
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/getInsertions.h:0: Warning: No relevant classes found. No output generated.
> [ 98%] Generating dxflib/src/moc_dl_dxf.cxx
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_dxf.h:0: Warning: No relevant classes found. No output generated.
> [ 98%] Generating dxflib/src/moc_dl_writer_ascii.cxx
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.h:0: Warning: No relevant classes found. No output generated.
> [ 98%] Generating qrc_dxf2shpconverter.cxx
> Scanning dependencies of target dxf2shpconverterplugin
> [ 99%] Building CXX object src/plugins/dxf2shp_converter/CMakeFiles/dxf2shpconverterplugin.dir/dxf2shpconverter.o
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp: In member function 'void dxf2shpConverter::addMyLayer(QString)':
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconverter.cpp:132: warning: unused variable 'lyr'
> [ 99%] Building CXX object src/plugins/dxf2shp_converter/CMakeFiles/dxf2shpconverterplugin.dir/dxf2shpconvertergui.o
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp: In member function 'void dxf2shpConverterGui::on_buttonBox_helpRequested()':
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp:130: warning: statement has no effect
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp:131: warning: statement has no effect
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp:132: warning: statement has no effect
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp:133: warning: statement has no effect
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp:134: warning: statement has no effect
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp:135: warning: statement has no effect
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp:136: warning: statement has no effect
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp:137: warning: statement has no effect
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp:138: warning: statement has no effect
> [ 99%] Building CXX object src/plugins/dxf2shp_converter/CMakeFiles/dxf2shpconverterplugin.dir/builder.o
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/builder.cpp: In member function 'virtual void Builder::addCircle(const DL_CircleData&)':
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/builder.cpp:398: warning: right-hand operand of comma has no effect
> [ 99%] Building CXX object src/plugins/dxf2shp_converter/CMakeFiles/dxf2shpconverterplugin.dir/getInsertions.o
> [ 99%] Building CXX object src/plugins/dxf2shp_converter/CMakeFiles/dxf2shpconverterplugin.dir/dxflib/src/dl_dxf.o
> [ 99%] Building CXX object src/plugins/dxf2shp_converter/CMakeFiles/dxf2shpconverterplugin.dir/dxflib/src/dl_writer_ascii.o
> In file included from /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.h:35,
>                  from /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp:34:
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer.h: In member function 'void DL_Writer::entityAttributes(const DL_Attributes&) const':
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer.h:337: error: 'strcasecmp' was not declared in this scope
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp: In member function 'virtual void DL_WriterA::dxfReal(int, double) const':
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp:72: error: 'strlen' was not declared in this scope
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp:81: error: 'strlen' was not declared in this scope
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp: In static member function 'static void DL_WriterA::strReplace(char*, char, char)':
> /home/shoofi/src/straight/qgis-trunk/src/plugins/dxf2shp_converter/dxflib/src/dl_writer_ascii.cpp:147: error: 'strlen' was not declared in this scope
> make[2]: *** [src/plugins/dxf2shp_converter/CMakeFiles/dxf2shpconverterplugin.dir/dxflib/src/dl_writer_ascii.o] Error 1
> make[1]: *** [src/plugins/dxf2shp_converter/CMakeFiles/dxf2shpconverterplugin.dir/all] Error 2
> make: *** [all] Error 2
Maciek
Maciej Sieczka
www.sieczka.org
