[Qgis-developer] geos c api note
Jürgen E. Fischer jef at norbit.de
Sun Aug 17 13:30:47 EDT 2008
Hi Martin,
On Sun, 17. Aug 2008 at 21:20:12 +0530, Martin Dobias wrote:
> Well, very recent library versions cause problems mostly for linux
> users which usually use packages from distros and manual installation
> of the libs discourages quite a lot
IMHO the change we need isn't that important, it's probably just a
sanity check and AFAIK there are other sanity checks missing.
QGIS compiles fine with current GEOS.
And we need to produce packages for all distributions anyway - is there
a distribution that carries own qgis packages?  That could include GEOS.
As it's just one more GEOS call, that probably won't break anything.
Not ideal, but just a temporary workaround.
> > > - may bring new bugs
> > That's true for almost every change.
> Yes, so why to do this work just before the release?
Because I wanted to package for OSGeo4W and use the dependencies there.
They only ship the C-API.   Maybe bad timing, but IMHO a move in the
right direction.
> You're right. I'm aware of the issues. On windows we have to build
> many deps by ourselves so building also geos is not such a problem.
> The thing about c++ api not being recommended is really something that
> we should avoid in long term. But doing it now just kills the
> development effort I (and others) would like to give to enhance qgis.
Hm, so we don't switch to the C-API while we still can with just little
effort, but instead plan to introduce more and more dependencies to the
C++-API, which we know we won't use in the long term and which makes the
switch require more effort?
Unless the C-API, which currently hides the different geometry classes
in GEOS, is changed heavily, which I doubt will happen, inheriting from
GEOS classes is IMHO a bad move.
> > So I think we should target the C-API and extend it if necessary in
> > cooperation with the geos folks.
> Indeed. However I would prefer the cooperation in way that first we
> list what we need, they make the necessary changes and then we can
> switch to C api.
Why not work more closely with the GEOS folks and do the changes
incrementally?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
