AW: Re: [Qgis-developer] printing branch ready for testing
Düster Horst Horst.Duester at bd.so.ch
Mon Aug 25 02:06:19 EDT 2008
John,
>I still have problems with the add map image tool not doing anything
>in the composer canvas. Just now, I opened print composer, clicked add
>new map, drew my bounding box and nothing happened. No map item, no
>frame on the screen. After adding a legend, the add new map tool
worked.
When you add a new bounding box to a map, you have to choose the option
cache in the preview select box. Sometimes it is necessary to click
update preview.
Hope this helps
Regards
Horst
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: John C. Tull [mailto:john.tull at wildnevada.org]
Gesendet am: Samstag, 23. August 2008 22:58
An: Marco Hugentobler
Cc: Qgis Developer List
Betreff: Re: [Qgis-developer] printing branch ready for testing
On Aug 21, 2008, at 8:28 AM, Marco Hugentobler wrote:
> Hi Tim,
> Good. I'm going to move the files into the corresponding dirs before
> merging
> the branch to trunk.
> Regards,
> Marco
Marco,
I just built rev 9137 on OS X, and that went fine. I am trying to test
the composer. Some things I can report:
The 'Export as Image' button does not seem to do anything for me.
Exporting to svg works, but fonts scale much larger than they appear
in the composer (this might be something you never touched, not sure).
Printing the composer image crashes qgis when I select 'Preview' in
the OS X print dialog (this basically sends the image to Preview.app,
OS X's image viewing software, rather than to a physical device).
Oddly, printing to a physical device worked. Choosing Save as PDF
under the PDF drop-down in the OS X print dialog also causes a crash.
frame on the screen. After adding a legend, the add new map tool worked.
Let me know if there is anything I can do to help you troubleshoot
these issues.
Thanks,
John
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080825/ee4c87be/attachment.html
