[Qgis-developer] no plugin installer present
Otto Dassau otto.dassau at gmx.de
Thu Aug 28 10:18:34 EDT 2008
On Thu, 28 Aug 2008 15:17:56 +0200
Carlos Dávila <cdavilam at jemila.jazztel.es> wrote:
> Otto Dassau escribió:
> > Hi Tim,
> > On Thu, 28 Aug 2008 07:25:22 +0200
> > "Tim Sutton" <tim at linfiniti.com> wrote:
> >> Hi Otto
> >> I have been building with qt4 on ubuntu for some time.
> > ok, I guess my problems are homemade. If I don't manage to fix it, I will
> > write again.
for openSUSE it now builds, although there are still CMake Warnings as I
wrote below. There were just dependency problems - missing packages. If you
like, I can send you the SUSE.spec file with all requirements directly. See
other Mail for more info about SUSE.
For Debian and Ubuntu I still need to find out, what is missing on my PC and
Laptop, but as Tim wrote, it should work. I can write a solution when I know
what happened.
> If you find a solution please write it here, as you are not the only one
> with this issue.
ok, good to know.
regards,
 Otto
> Regards
> Carlos
> > thanks a lot
> >  Otto
> >> regards
> >> tim
> >> On 8/27/08, Otto Dassau <otto.dassau at gmx.de> wrote:
> >>> Hi,
> >>> I have the same (similar) problem building packages on debian lenny and
> >>> OpenSUSE
> >>> SLE_10 and 10.2 using QT 4.4.x. packages.
> >>> ######## Warnings and Python not being built messages ...
> >>> CMake Warning (dev) at CMakeLists.txt:257 (ADD_DEFINITIONS):
> >>> Policy CMP0005 is not set: Preprocessor definition values are now escaped
> >>> automatically. Run "cmake --help-policy CMP0005" for policy details. Use
> >>> the cmake_policy command to set the policy and suppress this warning.
> >>> This warning is for project developers. Use -Wno-dev to suppress it.
> >>> CMake Warning (dev) at CMakeLists.txt:258 (ADD_DEFINITIONS):
> >>> CMake Warning (dev) at CMakeLists.txt:259 (ADD_DEFINITIONS):
> >>> CMake Warning (dev) at src/providers/grass/CMakeLists.txt:1
> >>> (ADD_DEFINITIONS):
> >>> CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:4
(ADD_DEFINITIONS):
> >>> CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:21
> >>> (ADD_DEFINITIONS):
> >>> QGIS builds but then I don't have python incl. the plugin installer
> >>> available
> >>> with the error message like this on a debian lenny starting qgis
> >>> #PyQGIS konnte nicht geladen werden.
> >>> #Die Python-Unterstützung wird abgeschaltet.
> >>> #Traceback (most recent call last):
> >>> #  File "", line 1, in
> >>> #ImportError: No module named qgis.core
> >>> #Python-Version:
> >>> #2.5.2 (r252:60911, Aug 16 2008, 14:40:27)
> >>> #[GCC 4.3.1]
> >>> #Python-Pfad:
> >>> #['/python', '/home/dassau/.qgis//python/plugins', '/python/plugins',
> >>> #'/usr/lib/python25.zip', '/usr/lib/python2.5',
> >>> #'/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
> >>> #'/usr/lib/python2.5/lib-dynload',
'/usr/local/lib/python2.5/site-packages',
> >>> #'/usr/lib/python2.5/site-packages',
> >>> '/usr/lib/python2.5/site-packages/Numeric',
> >>> #'/usr/lib/python2.5/site-packages/PIL',
> >>> #'/usr/lib/python2.5/site-packages/gst-0.10',
> >>> #'/var/lib/python-support/python2.5',
> >>> #'/usr/lib/python2.5/site-packages/gtk-2.0',
> >>> #'/var/lib/python-support/python2.5/gtk-2.0']
> >>> at http://lists.osgeo.org/pipermail/qgis-user/2008-August/003289.html
> >>> people said they had to downgrade python-qt4 package to version 4.3.3. to
> >>> make
> >>> it work.This would be really bad for me since I am just preparing the
> >>> opensuse
> >>> build server to create all QGIS 1.0 opensuse rpms with a current QT4
(4.4.x)
> >>> version.
> >>> So my question :): Is my plan possible at all to build QGIS with QT4
> >>> (4.4.x).
> >>> Is there a solution to fix this or which QT versions work at the moment?
> >>> thanks a lot
> >>>  Otto
> >>> On Wed, 20 Aug 2008 14:28:14 +0200
> >>> Maciej Sieczka <tutey at o2.pl> wrote:
> >>>> Maciej Sieczka pisze:
> >>>>>> In current trunk (r9046) the plugin installer plugin is not present in
> >>>>>> the plugins manager menu. What's wrong?
> >>>>> After a rebuild from SVN today, I have the Plugin Installer present.
> >>>> ... and after another rebuild yesterday it's gone again. Same as the
> >>>> Python console. What's up?
> >>>>> When is the 0.05.4 from
> >>>>> http://bwj.aster.net.pl/qgis/plugins.xml going to be included?
> >>>> (Bump.) Feature freeze is near. It could use some testing.
> >>>> Maciek
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
