[Qgis-developer] QGIS 0.11.0 rpm also available for older SUSE
Otto Dassau otto.dassau at gmx.de
Thu Aug 28 10:27:24 EDT 2008
Dear QGIS-user,
QGIS 0.11.0 rpm packages are now also available for older SUSE versions.
a) For "uptodate" openSUSE versions you can install QGIS 0.11.0 (and related
packages) as usuall from the Application:Geo Repository at:
http://download.opensuse.org/repositories/Application:/Geo/
openSUSE 10.3: it builds with libqt4-4.3.1 and python-qt4-4.3
openSUSE 11.0: it builds with libqt4-4.4.0 and python-qt4-4.4.2
openSUSE Factory (Testing): it builds with libqt4-4.4.1 and python-qt4-4.4.3
b) Then, there is now a new Repository called Application:Geo:QT4. If you
want/have to use QGIS with older openSUSE versions you need to add both
Repositories:
http://download.opensuse.org/repositories/Application:/Geo:/QT4/
to your package installer and then get QGIS 0.11.0 incl. current QT4 and
python-qt4 for:
openSUSE 10.2: it builds with libqt4-4.4.1 and python-qt4-4.4.3
SLE_10: it builds with libqt4-4.4.1 and python-qt4-4.4.3
 regards,
  Otto
