[Qgis-developer] QGIS 0.11.0 crashes when clicking on the
projection-selector
Otto Dassau
otto.dassau at gmx.de
Sat Aug 30 09:03:53 EDT 2008
I tried to use WITH_INTERNAL_SQLITE3=TRUE in my cmake configuration as listed
below;
cmake -Wno-dev \
-D CMAKE_INSTALL_PREFIX=%{_prefix} \
-D GRASS_PREFIX=/opt/grass\
-D QGIS_LIB_SUBDIR=%{lib} \
-D QGIS_PLUGIN_SUBDIR=%{lib}/qgis \
-D QGIS_MANUAL_SUBDIR=share/man \
-D WITH_INTERNAL_SQLITE3=TRUE .
and get error messages during compilation of QGIS 0.11.0:
[ 41%] Building CXX object src/app/CMakeFiles/qgis.dir/qgsbookmarkitem.o
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:20:21: error:
sqlite3.h: No such file or directory
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp: In member
function 'void QgsBookmarkItem::store()':
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:42: error:
'sqlite3' was not declared in this scope
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:42: error: 'db'
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:47: error:
'sqlite3_open' was not declared in this scope
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:50: error:
'sqlite3_errmsg' was not declared in this scope
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:58: error:
'sqlite3_stmt' was not declared in this scope
'ppStmt' was not declared in this scope
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:76: error:
'sqlite3_prepare' was not declared in this scope
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:78: error:
'SQLITE_OK' was not declared in this scope
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:81: error:
'sqlite3_step' was not declared in this scope
'SQLITE_DONE' was not declared in this scope
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:85: error:
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:88: error:
'sqlite3_finalize' was not declared in this scope
/usr/src/packages/BUILD/qgis-0.11.0/src/app/qgsbookmarkitem.cpp:90: error:
'sqlite3_close' was not declared in this scope make[2]: ***
[src/app/CMakeFiles/qgis.dir/qgsbookmarkitem.o] Error 1 make[1]: ***
[src/app/CMakeFiles/qgis.dir/all] Error 2 make: *** [all] Error 2
maybe someone can help and tell if I used the cmake option
in a wrong way or if it is a bug in QGIS?
thanks a lot
Otto
On Fri, 29 Aug 2008 16:26:02 +0200
Otto Dassau <otto.dassau at gmx.de> wrote:
> On Fri, 29 Aug 2008 16:24:11 +0200
> Stephan Holl <stephan.holl at intevation.de> wrote:
> > Hello Jürgen,
> > Jürgen E. Fischer <jef at norbit.de>, [20080829-16:14:03]:
> > > Hm, dunno. I'm running 3.5.9 on Debian and 3.5.1 on cygwin.
> > > And qgis includes a sqlite3 3.5.6 in src/core that can be enabled by
> > > setting WITH_INTERNAL_SQLITE3.
> > Excellent news! So configuring with
> > should solve my problems for now...
> > I will try.
> > TIA
> > Stephan
> > @Otto, are you willing to change that at least for SLE_10 in the
> > spec_file?
> of, course :-), thanks for your investigations
> Otto
> Qgis-developer mailing list
