[Qgis-developer] Requirement for int4 column on PostGIS access
Jürgen E. Fischer
jef at norbit.de
Sat Aug 30 11:31:58 EDT 2008
Hi Jochen,
On Sat, 30. Aug 2008 at 16:42:42 +0200, Jochen Topf wrote:
> Is the limitation on int4 columns something hardcoded deep in the code
> or is it something that could be changed reasonably easy?
Just supporting the different type isn't a big problem. But QGIS is
currently tied to 32bit feature ids (as is OGR btw). So once you leave
that range you'd run into problems.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
