[Qgis-developer] Usefull methods
vatto
mauricio.dev at gmail.com
Wed Dec 10 09:10:00 EST 2008
I've written some methods to work with layers' names. I found the usefull and
usually being used in every script I make. Shouldn't these stuff be a default
in the API? Well, the python code is here. It shouldn't be hard to translate
do C++.
def listLayers(self,layertype):
layersmap=QgsMapLayerRegistry.instance().mapLayers()
layerslist=[]
for (name,layer) in layersmap.iteritems():
if (layertype==layer.type()):
layerslist.append(layer.name())
return layerslist
def getLayerByName(self,layerName):
if (layerName==layer.name()):
return layer
Maurício de Paulo
