[Qgis-developer] please help me write a QGIS-PostGIS GUI in
Python
Maciej Sieczka
tutey at o2.pl
Sat Feb 2 17:26:30 EST 2008
Alessandro Pasotti pisze:
> Did you take a look to my code?
Yes. It helps. Thanks a lot!
We have slightly different approaches I see. You don't seem to be
allowing for schemas other than default "public". Thus your GUI does not
have a way to select a schema. I think it is important to not to assume
everyone uses public schema always. Thus I think trying to follow the
"add postgis layers" QGIS GUI, which supports different schemas, is a
more robust approach.
I have progressed a bit. Code attached. I've got the Postgres
connections selector working, know how to connect actions to buttons,
parse connection parameters and pass them to psycopg.
My current problem is how to get the TreeView, which provides schemas
and tables list, to work from python. It's the 'self.mTablesTreeView'
bit from ui_plugingui.py. C++ implementation is in
src/app/qgsdbsourceselect.cpp.
The aim is to fetch schemas and tables list according to psycopg command
and populate the plugin's window with them, letting the user to select
schemas and tables for further actions. If you or anybody could help me
with this it'd be great.
Maciek
Type: application/x-bzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080202/b907a571/qgis_postgis_gui_v3.tar.bin
