[Qgis-developer] Building GRASS/QGIS with MSYS
marco.pasetti at alice.it
Tue Feb 5 04:40:34 EST 2008
Hi Tisham,
>There are some issues with GDAL support on MINGW so the little 'sed' line hacks the libtool to work properly.
>Please let me know if you need help with any particular steps.
>Regards,
>Tishampati Dhar
I built all following the wiki, using Paul Kelly's prebuilt extralibs and your suggestions about gdal, grass-6.3.0RC4 and qgis 0.9.1, but I have linking problems (procedure entry point X509_STORE_set_flags could not be located in the dynamic link library libeay32.dll), so I decided to restart to build all. Probably I found some "things to change" in the wiki, but I don't want to overbalance since I check everithing is working...
Now the question: is with-libtool necessary for gdal? because there are some things not clear to me about this passage.. after building gdal level one, it says:
./configure --with-ngpython --with-xerces=/local/ --with-jasper=/local/ --with-grass=/local/grass-6.3.cvs/ --with-pg=/local/pgsql/bin/pg_config.exe
1) neither python nor grass and postgresql are install at this step of the guide; how could that be? do I really need this "line" and the following "sed"?
2) the same problem comes at the end of gdal level two... same questions ;-)
after that... I configured grass as follow:
export PATH="/usr/local/bin:/usr/local/lib:$PATH"
./configure --prefix=/usr/local --bindir=/usr/local \
--with-includes=/usr/local/include --with-libs=/usr/local/lib \
--with-cxx --without-jpeg --without-tiff \
--with-postgres --with-postgres-includes=/usr/local/pgsql/include --with-postgres-libs=/usr/local/pgsql/lib \
--with-opengl=windows --with-fftw \
--with-freetype --with-freetype-includes=/usr/local/include/freetype2 \
--without-x \
--with-tcltk --with-tcltk-includes=/c/programmi/tcl/include --with-tcltk-libs=/c/programmi/tcl/bin \
--enable-x11=no --enable-shared=yes --with-proj-share=/usr/local/share/proj \
--with-sqlite --with-sqlite-includes=/usr/local/include --with-sqlite-libs=/usr/local/lib
with this result:
GRASS is now configured for: i686-pc-mingw32
Source directory: /usr/local/src/grass-6.3.0RC4
Build directory: /usr/local/src/grass-6.3.0RC4
Installation directory: ${prefix}/grass-6.3.0RC4
Startup script in directory: /usr/local
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
Building shared libraries: yes
64bit support: no
OpenGL platform: Windows
NVIZ: yes
BLAS support: no
C++ support: yes
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GLw support: no
JPEG support: no
LAPACK support: no
Large File Support (LFS): yes
Motif support: no
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: yes
Python support: no
Readline support: no
SQLite support: yes
Tcl/Tk support: yes
TIFF support: no
X11 support: no
MacOSX application: no
But also with the following warnings:
configure: warning: *** Unable to locate iconv() function.
configure: warning: *** Unable to locate socket() function.
configure: warning: *** --with-opengl=windows is untested.
I decided to add Tcl/Tk support to be able to test some new grass modules I added before to be "qgis ready";
Thanks for your support,
Marco
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080205/fe4a36c8/attachment.html
