[Qgis-developer] Compilation error rev. 8117
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Fri Feb 8 05:03:11 EST 2008
Horst,
The compilation works for me with rev. 8117.
Could you set the cmake variable 'CMAKE_VERBOSE_MAKEFILE' to true and then
post the compiler output when trying to compile graticulcreator.cpp? Ideally,
there should be -I<GEOS_INCLUDE_PATH> in the compiler command line.
Regards,
Marco
Am Freitag 08 Februar 2008 10:08:34 schrieb Düster Horst:
> I do have problems to compile QGIS rev. 8117. The compilation process
> crashes with the following error message
> [ 75%] Building CXX object
> src/plugins/grid_maker/CMakeFiles/gridmakerplugin.dir/graticulecreator.o
> In Datei, eingefügt von
> /usr/local/src/sogis/qgis_src/qgis_trunc/src/plugins/grid_maker/graticul
> ecreator.cpp:17:
> /usr/local/src/sogis/qgis_src/qgis_trunc/src/plugins/grid_maker/../../co
> re/qgsgeometry.h:25:26: geos/version.h: File or directory not found
> I believe, that GEOS is installed correctly with ccmake. The mentioned
> file exists under GEOS_INCLUDE_PATH/geos/version.h
> What goes wrong.
> Regards
> Horst
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
