[Qgis-developer] Re: provider.getNextFeature(fet) with PostGIS
Martin Dobias wonder.sk at gmail.com
Wed Feb 13 07:13:50 EST 2008
On Feb 13, 2008 12:14 PM, Düster Horst <Horst.Duester at bd.so.ch> wrote:
> provider.getNextFeature()
> doesn't work no more with PostGIS layers. It works fine with *.shp layers.
> Maybe the same issue like setAttributeMap()???
No, calls to providers are handled in a generic way using
QgsVectorDataProvider, your problem must be elsewhere.
> Geoprocessing Plugin:
> >In my opinion you can put your plugin to the repository, maybe some
> >people would like to join your efforts!
> How can I put the plugin to the repository??
Here's the plugin repository home:
http://www.spatialserver.net:3001/
You can register there and upload the plugin, later plugin installer
will be able to download and install it.
Martin
