AW: Re: [Qgis-developer] Python Geprocessing Plugin
John C. Tull
john.tull at wildnevada.org
Tue Feb 19 12:03:43 EST 2008
Here is a debug message from trying out the plugin in a debug build
with two shapefiles:
2/19/08 8:59:43 AM [0x0-0x13d13d].org.qgis.qgis[93141] An error has
occured while executing Python code:
File "/Users/jctull/.qgis//python/plugins/geoprocessing/
geoprocessing.py", line 187, in manageGui
myListA = self.getLayerNames("all")
geoprocessing.py", line 424, in getLayerNames
if layer.type() == QgsMapLayer.VECTOR and layer.vectorType() >=
myType and not layer.name() in layerNamesList:
AttributeError: 'NoneType' object has no attribute 'type'
On Feb 18, 2008, at 11:11 PM, Düster Horst wrote:
> John,
> I can't test your point 2 due to missing access to a Mac Box.
> Perhaps someone else can take a look at John's porblem?
> Regards
> Horst
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> -----Ursprüngliche Nachricht-----
> Von: John C. Tull [mailto:john.tull at wildnevada.org]
> Gesendet am: Montag, 18. Februar 2008 21:29
> An: Düster Horst
> Cc: qgis-developer at qgis.org; qgis-user
> Betreff: Re: [Qgis-developer] Python Geprocessing Plugin
> Horst,
> The first problem below was resolved by Gary Sherman. I had an older
> version of the Plugin Installer in the plugin folder. Removing that
> allowed the built-in installer plugin to run, and that fixed the
> permissions problem.
> Still no luck with problem 2 at this point. I tried on my ubuntu vm
> and the menu worked as expected, so this may be a mac-specific issue.
> Cheers,
> John
> On Feb 18, 2008, at 11:24 AM, John C. Tull wrote:
> > Horst,
> > I tried on OS X. Here are my observations and issues so far:
> > 1) The installer does not work. I get a permissions error when
> > trying to use the python installer. Manual installation works ok.
> > 2) When I run the plugin in a project with available vectors, the
> > drop-down menu for selecting a vector to geoprocess does not
> > populate with anything. So I am unable to perform any geoprocessing
> > because there are not vectors available to work on in the gui.
> > Because of problem 2), I am unable to get very far in testing this.
> > I will be around on the irc channel today and off-and-on this week
> > if you want to try and work out some things online.
> > Thanks,
> > John
> > On Feb 17, 2008, at 2:30 AM, Düster Horst wrote:
> >> A new Geoprocressing Python plugin is available in the Python
> >> Plugin Repository.
> >> http://spatialserver.net:3001
> >> This plugin is under developement and offers vector analysis
> >> functions for ogr and postgis vector data.
> >> The following functions are available:
> >> - Buffer
> >> - Convex Hull
> >> - Difference A - B
> >> - Dissolve
> >> - Intersection
> >> under developement:
> >> - SymDifference
> >> - Union
> >> The plugin needs QGIS Rev. 8153 or higher!
> >> The plugin uses the GEOS library. I recommend the use of
> GEOS-3.0.0.
> >> Unfortunately there are some issues with GEOS. In some cases GEOS
> >> throws topology exceptions when you try to dissolve large datasets
> >> => QGIS crashes.
> >> I hope that this plugin can be helpful for you and I look forward
> >> for your comments and ideas.
> >> Regards
> >> Horst
> >> Dr. Horst Düster
> >> Kanton Solothurn
> >> SO!GIS Koordination
> >> Rötistrasse 4
> >> CH-4501 Solothurn
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.qgis.org
> >> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080219/2e75b4ae/attachment.html
