[Qgis-developer] Patch for screen updates during long rendering
operations
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Sat Jan 5 10:55:57 EST 2008
I tested the patch on Mac and Windows as well and it seems to work fine. I
therefore commited the patch to trunk.
Developers, please test the incremental screen update too and report problems
to the bugtrackers.
cheers,
Marco
Am Sonntag 30 Dezember 2007 09:21:01 schrieb Marco Hugentobler:
> Hi Martin,
> Thanks for looking into this. I think you are right, everything runs just
> in one thread and we don't need mutexes. So I attached a second version of
> the patch that includes your changes to qgsmapcanvas.cpp (and contains one
> additional if(mDrawing) query).
> I'd like to apply the patch to trunk before the feature freeze for 0.9.2,
> which is on 10th January. Everybody is invited to test the patch,
> especially on other platforms.
> > Footnotes :)
> > - we can enable emitting drawingProgress in QgsMapRender to show the
> > progress bar while rendering
> > - we can call processEvents() also after rendering every layer (to
> > update the progress bar and optionally also map in canvas)
> +1. It will be great to have the progress bar back!
> > What interests me here most is cancellation of the rendering. In some
> > thread on qgis-dev I've been raving already about something called
> > rendering context, which would contain all those parameters we'd like
> > to pass to layers when drawing and we would pass only that object
> > instead of all the arguments:
> > - painter
> > - extent to draw
> > - transformation between map and screen coordinates
> > - transformation between layer and map coordinates
> > - whether we're in overview or not
> > - (in future) scaling parameters
> > For me the best solution would be to add a flag "rendering cancelled"
> > to that context which would be set by application in case user hits
> > Esc.
> > As you can see this would mean also some small changes in qgis
> > libraries (to add the rendering context) but the changes can be done
> > without breaking current API - we could keep original layers' draw()
> > functions and mark them as deprecated.
> Yes, it is very important to have the possibility to cancel long
> renderings. In my opinion it is worth to do some API changes and to have it
> prior to version 1.0 (coded as usual in a development branch).
> Regards and a happy new year,
> Marco
> Am Dienstag 25 Dezember 2007 02:52:49 schrieb Martin Dobias:
> > Hey Marco,
> > finally I've took a look at the patch and I have some comments:
> > - from the few tests I've done the patch behaves well :-)
> > - you use mutexes in the patch. Mutexes are good for synchronization
> > between threads, but QGIS runs in one thread - so is it really
> > necessary? What we're trying to acheive is to protect the functions
> > from indirect recursion - resizeEvent calls rendering, rendering calls
> > event loop, event loop calls resizeEvent... But it's all done just in
> > one thread so we should be perfectly OK just with some (e.g. static)
> > variables that would indicate if we're already in resizeEvent or not.
> > I've tried it and seems to work fine.
> > - the same applies to refresh() - it suffices to skip the refresh if
> > mDrawing flag is already true.
> > - we don't need to store queue of all resizes, we need to store just
> > the last one. Moreover if we were using threads, that variable
> > mResizeQueue should have been also guarded by mutex (in the current
> > implementation of resizeEvent it's not).
> > I've attached my changes in qgsmapcanvas.cpp (I've changed only
> > resizeEvent() and refresh()) if you're interested in my solution
> > (works for me on linux).
> > Footnotes :)
> > - painter
> > - extent to draw
> > Esc.
> > This change is important also for fixing the map composer since we
> > should add new flag that would indicate whether the output must be
> > vector (print or export to PDF/SVG) or can be raster (drawing to
> > screen). In case of raster output we can cache symbols as bitmaps.
> > Unfortunately this caching is currently happening also with vector
> > output and thus resulting with ugly appearance of symbols.
> > Happy holidays
> > Martin
> > On Dec 22, 2007 12:06 PM, Marco Hugentobler
> > <marco.hugentobler at karto.baug.ethz.ch> wrote:
> > > The problem on Mac seems to be the flag Qt::excludeUserInputEvents.
> > > Obviously, the resize event is a user input event on Mac, but not on
> > > Win and Linux :-)
> > > Please test this new patch, it works for me also on Mac. As
> > > QApplication->processEvents() is used now instead
> > > QApplication->processEvents(Qt::excludeUserInputEvents), some queries
> > > have been added to prevent users from adding layers, removing layers,
> > > zooming, etc. while the drawing is in progress.
> > > Regards,
> > > Marco
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
