[Qgis-developer] Clipping symbols
Steven Bell
botsnlinux at gmail.com
Tue Jan 8 18:59:31 EST 2008
Can we all agree that instead a symbol with pointSize=10 should render a
circle with radius=5, a rectangel with side=10, a diamond with
*diagonal*=10 and a triangle with base and height=10. They will then all
have different areas.
I would vote for that. When you specify a size in pixels, millimeters, or
map units, you expect the symbol to be that size, not some area-equivalent
size. Note that an equilateral triangle (if that's what the symbol is meant
to be) will have a base of 10 and a height less than 10. On a similar note,
some of the svg point symbols should be modified to fill the entire svg
canvas.
Steven
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080108/981c3e34/attachment.html
