[Qgis-developer] Digitising icons
    Düster Horst
    Horst.Duester at bd.so.ch
    Fri Jan 11 04:14:22 EST 2008
In addition to your mentioned ideas all layers in editing mode should be
signed as toggled to editing in the legend list.
Regards
Horst
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: Marco Hugentobler [mailto:marco.hugentobler at karto.baug.ethz.ch]
Gesendet am: Freitag, 11. Januar 2008 08:57
An: Tim Sutton
Cc: qgis-developer
Betreff: Re: [Qgis-developer] Digitising icons
Hi Tim,
Thanks for your help. I also think that the digitising tools would
benefit
from some polishing.
>  - I would like to revise the digitising icons - they are not all
> consistent and in retrospect that blue background I put behind icons
> reduces contrast and makes it hard to visually separate one from the
> other. I've made a quick mockup in the GIMP (attached). If folks are
> happy with those as concept Ill do them more neatly (in particularly
> anti-aliased) as svgs and then export to pngs. Any objections?
+1. The new icons look good and I think they are clearer. E.g. the
difference
move features / move Vertex is clearer visible and also the meaning of
'add
ring' and 'add island' operation is easier to get.
> - The slow point for me in digitising now is atrribute data capture.
> In particular working with keyboard or mouse involves extra clicks to
> move between fiellds - when you capture a lot of data these all add up
> to a chunk of time lost. I propose as a short term fix to make the
> field names row headings rather than cell values to eliminate needing
> to tab through field headings when jumping from cell to cell. In the
> longer term I would like to change the ui to dynamically generate a
> form with suitable widgets based on the data type being entered. Ill
> come back to that in a future release though.
I don't understand what you mean with the short time fix. Do you mean to
enable the possibility to jump from the end of a column to the beginning
of
the next with tab key?
> - the vertex marker cross hairs  are in my opinion too long and take
> on the pen style of the layer which can look a bit strange at times.
> As a short term fix I would like to suggest shortening the length of
> the marker arms and use a standard red, 2px pen for rendering them. In
> the longer term it might be nice to use little circles.
Yes, a circle or maybe a square with transparent fill would be nice. I'm
going
to take a look at udig and jump to see what they use.
> - we should aim to use a single icon for capturing point line or
> polygon with its image being changed in accordance to the context of
> the layer type being edited.
Also in my opinion, the digitising toolbar takes too much space. I'd
like to
use a dropdown list for the tools. So there would be only a button for
start/stop editing and a dropdown list for the tools.
Regards,
Marco
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
Qgis-developer mailing list
Qgis-developer at lists.qgis.org
http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080111/ad28915d/attachment.html
