[Qgis-developer] Building QGIS From Source Under Windows Using MSYS
marco.pasetti at alice.it
Thu Jan 17 07:07:58 EST 2008
Hello,
I want to build QGIS under windows; I started reading in the QGIS wiki about compilation (BuildingFromSource document)http://wiki.qgis.org/qgiswiki/BuildingFromSource
After reading introduction and building notes, I jumped to section
3. Building under windows using msys
in this section I read in 3.1 that I can use a pre-built MSYS enviroment with all dependencies, or create it by myself one following the instructions detailed in section 6; because i want to build a new GRASS module I decided for the last.
QUESTION: After completing instructions in section 6, I have to follow section 3, starting from 3.2. Is that right?
6. Creation of MSYS environment for compilation of Quantum GIS
6.1. Initial setup
I exactly followed instructions detailed in section 6.1; about that I would remark:
http://puzzle.dl.sourceforge.net/sourceforge/mingw/MSYS-1.0.11-2004.04.30-1.exe <http://puzzle.dl.sourceforge.net/sourceforge/mingw/MSYS-1.0.11-2004.04.30-1.exe> link is dead!
I used instead: http://prdownloads.sourceforge.net/mingw/MSYS-1.0.11-2004.04.30-1.exe?download
http://puzzle.dl.sourceforge.net/sourceforge/mingw/MinGW-5.1.3.exe link is dead!
I used instead: http://downloads.sourceforge.net/mingw/MinGW-5.1.3.exe?modtime=1168811236&big_mirror=1 <http://downloads.sourceforge.net/mingw/MinGW-5.1.3.exe?modtime=1168811236&big_mirror=1>
6.2. Installing dependencies
6.2.1. Getting ready
I downloaded Paul Kelly's package of precompiled libraries for GRASS and unpacked in c:\msys\local
6.2.2. GDAL level one
I exactly followed all the instructions, except:
GDAL build procedure can be greatly simplified to use libtool with a libtool line patch: configure gdal as below: ./configure --with-ngpython --with-xerces=/local/ --with-jasper=/local/ --with-grass=/local/grass-6.3.cvs/ --with-pg=/local/pgsql/bin/pg_config.exe
Then fix libtool with: mv libtool libtool.orig cat libtool.orig | sed 's/max_cmd_len=8192/max_cmd_len=32768/g' > libtool
Because I didn't understand well those instructions.
QUESTION: What should I do?
6.2.3. GRASS
I followed all the instructions detailed in this section, using grass-6.3.0RC4 source. After compiling I have the following compilation log:
GRASS GIS compilation log
Started compilation: Wed Jan 16 17:39:21 GMT 2008
Errors in:
/usr/local/src/grass-6.3.cvs/imagery/i.class
/usr/local/src/grass-6.3.cvs/imagery/i.ortho.photo/photo.2image
/usr/local/src/grass-6.3.cvs/imagery/i.ortho.photo/photo.2target
/usr/local/src/grass-6.3.cvs/imagery/i.ortho.photo/photo.rectify
/usr/local/src/grass-6.3.cvs/imagery/i.points
/usr/local/src/grass-6.3.cvs/imagery/i.vpoints
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.daemon
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.edgedensity
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.patchdensity
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.patchnum
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.shape
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.simpson
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.shannon
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.mps
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.mpa
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.padcv
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.padsd
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.padrange
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.cwed
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.richness
/usr/local/src/grass-6.3.cvs/raster/r.li/r.li.dominance
/usr/local/src/grass-6.3.cvs/raster/r.terraflow
/usr/local/src/grass-6.3.cvs/visualization/nviz
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed Jan 16 18:37:48 GMT 2008
QUESTIONS: --------------------------------------------------------------------------------------------------------------------------------------------------------------
1. those errors are dued to not complete execution of instruction in 6.2.2, or should I recompile GRASS libraries by myself?
2. to fix errors should I simply re-apply instructions from 6.2.2, or should I detelete something?
Thanks for all your help,
Marco
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080117/e3d25f70/attachment.html
