[Qgis-developer] How do I change the symbol and its size from a
provider?
Ken Roser
kroser at roser.us
Wed Jan 23 12:19:59 EST 2008
Sorry if I wasn't too clear. Let me try to present the problem just a
bit differently.
Let's say I'm using the delimited text plugin and provider, as is, in
the source code, but I want to modify it so that the points are
displayed as triangles instead of squares and at size 20 instead of the
default. These choices would be built into the software, i.e., not user
selectable. How would I do that?
Tim Sutton wrote:
> Hi Ken
> I'm not sure that it makes sense to set symbology in your provider
> itself so Im hoping you are trying to do it from some kind of add
> layer gui, but you havent provided much information for me to know
> whats really going on. That said here is how you can set the symbol on
> a new vector layer instance programmatically:
> 1572 QgsSymbol * mypSymbol = new
> QgsSymbol(mypVectorLayer->vectorType());
> 1573 QColor
> myPresenceColor(mySettings.value("mapping/presenceColour",QColor(Qt::green).name()).toString());
> 1574 mypSymbol->setFillColor(myPresenceColor);
> 1575 mypSymbol->setColor(Qt::black); //outline
> 1576 mypSymbol->setPointSize(mySymbolSize);
> 1577 mypSymbol->setFillStyle(Qt::SolidPattern);
> 1578 QgsSingleSymbolRenderer *mypRenderer = new
> QgsSingleSymbolRenderer(mypVectorLayer->vectorType());
> 1579 mypRenderer->addSymbol(mypSymbol);
> 1580 mypVectorLayer->setRenderer(mypRenderer);
> The above is a single symbol renderer take from one of my cpp
> projects. The same project also implements a unigue value renderer -
> see the original source at http://tinyurl.com/3xystm for more info.
> I hope that helped!
> Regards
> Tim
> 2008/1/23, Ken Roser <kroser at roser.us>:
>> I'm writing a plugin/provider that's similar in functionality to the
>> delimited text plug in. Things are working well, but I need to change
>> the size, color and possibly the symbol itself when I add a point to the
>> map. I've been unable to determine a method of doing so other than
>> going to the symbology tab on the layer properties dialog. I want the
>> change to happen automatically via the provider code. Can anyone help out?
>> Qgis-developer mailing list
>> Qgis-developer at lists.qgis.org
>> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
