[Qgis-developer] WinGRASS Building Instructions And QGIS
Compile Enviroment
Tim Sutton
tim at linfiniti.com
Thu Jan 24 11:32:50 EST 2008
Hi Marco
Ideally changes to the building from source procedure should be
submitted as a patch to INSTALL.t2t which is the master document that
the INSTALL text docuemnt and BuildingFromSource wiki page get
generated from. You can fine INSTALL.t2t in the top level of the QGIS
svn checkout.
Regards
Tim
2008/1/24, marco.pasetti at alice.it <marco.pasetti at alice.it>:
> Hi,
> in WinGRASS Current Status (from GRASS wiki) I read as follows:
> After compiling [GRASS] you should copy libxdr.dll, libproj.dll, libpng.dll,
> libgdal-1.dll and libz.dll.1.2.3 into the GRASS lib directory and all the
> GDAL and PROJ .exe files in the bin directory into the GRASS bin directory,
> and then you have a more or less self-contained GRASS distribution.
> is that necessary even if I want to use grass only with grass plug-in in
> QGIS?
> Thanks
> PS: I'm building qgis+grass by myself on windows, creating my own msys
> enviroment; I'm also in contact with grass-dev list, and I think that some
> instructions in
> http://wiki.qgis.org/qgiswiki/BuildingFromSource should be
> fixed. What should I do?
> Thanks
> Marco
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
