[Qgis-developer] R: R: WinGRASS Building Instructions And QGIS
Compile Enviroment
marco.pasetti at alice.it
Fri Jan 25 07:29:27 EST 2008
Hi Tim,
roger that. I'm still collecting change proposals. I will do taht maybe this evening or tomorrow morning.
Bye,
Marco
Da: Tim Sutton [mailto:tim at linfiniti.com]
Inviato: ven 25/01/2008 1.07
A: marco.pasetti at alice.it
Cc: QGIS Developer Mailing List
Oggetto: Re: R: [Qgis-developer] WinGRASS Building Instructions And QGIS Compile Enviroment
Hi
If you have a svn checkout of qgis (which I figure you will be doing
if you are planning to build from source) you will find it in the top
level checkout dir. Alternatively you can just cehck out that one file
like this:
mkdir qgis_tmp
cd qgis_tmp
svn co https://svn.qgis.org/repos/qgis/trunk/qgis/INSTALL.t2t
make your edits, then submit your changes to the qgis trac or to a
qgis dev using the procedure described here:
http://wiki.qgis.org/qgiswiki/DevelopersManual#head-fab2f4f09fd38b13648712795e4ce9a108677f71
Best regards
Tim
2008/1/24, Marco Pasetti <marco.pasetti at alice.it>:
> Hi Tim,
> I found INSTALL.t2t at
> How can I modify the document (indicating where I placed modifications) and
> then how can I propose my changes?
> Regards,
> Marco
> -----Messaggio originale-----
> Inviato: giovedì 24 gennaio 2008 17.33
> Cc: qgis-developer at lists.qgis.org
> Oggetto: Re: [Qgis-developer] WinGRASS Building Instructions And QGIS
> Compile Enviroment
> Hi Marco
> Ideally changes to the building from source procedure should be submitted as
> a patch to INSTALL.t2t which is the master document that the INSTALL text
> docuemnt and BuildingFromSource wiki page get generated from. You can fine
> INSTALL.t2t in the top level of the QGIS svn checkout.
> Regards
> Tim
> 2008/1/24, marco.pasetti at alice.it <marco.pasetti at alice.it>:
> > Hi,
> > in WinGRASS Current Status (from GRASS wiki) I read as follows:
> > After compiling [GRASS] you should copy libxdr.dll, libproj.dll,
> > libpng.dll, libgdal-1.dll and libz.dll.1.2.3 into the GRASS lib
> > directory and all the GDAL and PROJ .exe files in the bin directory
> > into the GRASS bin directory, and then you have a more or less
> self-contained GRASS distribution.
> > is that necessary even if I want to use grass only with grass plug-in
> > in QGIS?
> > Thanks
> > PS: I'm building qgis+grass by myself on windows, creating my own msys
> > enviroment; I'm also in contact with grass-dev list, and I think that
> > some instructions in http://wiki.qgis.org/qgiswiki/BuildingFromSource
> > should be fixed. What should I do?
> > Thanks
> > Marco
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Tim Sutton
> QGIS Project Steering Committee Member - Release Manager Visit
> http://qgis.org <http://qgis.org/> for a great open source GIS openModeller Desktop Developer
> Visit http://openModeller.sf.net <http://openmodeller.sf.net/> for a great open source ecological niche
> modelling tool Home Page: http://tim.linfiniti.com <http://tim.linfiniti.com/>
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
Tim Sutton
Visit http://qgis.org <http://qgis.org/> for a great open source GIS
niche modelling tool
Skype: timlinux
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080125/4ff34044/attachment.html
