[Qgis-developer] QGIS Building On Windows - CMake Setup Problems
    marco.pasetti at alice.it
    Mon Jan 28 11:29:42 EST 2008
Skipped content of type multipart/alternative-------------- next part --------------
BINDINGS_GLOBAL_INSTALL				OFF
BISON_EXECUTABLE					C:/msys/local/bin/bison.exe
CMAKE_AR						c:/msys/mingw/bin/ar.exe
CMAKE_BACKWARDS_COMPATIBILITY			2.4
CMAKE_BUILD_TYPE
CMAKE_COLOR_MAKEFILE				ON
CMAKE_CXX_COMPILER					c:/msys/mingw/bin/g++.exe
CMAKE_CXX_FLAGS					''
CMAKE_CXX_FLAGS_DEBUG				-g
CMAKE_CXX_FLAGS_MINSIZEREL				-Os -DNDEBUG
CMAKE_CXX_FLAGS_RELEASE				-O3 -DNDEBUG
CMAKE_CXX_FLAGS_RELWITHDEBINFO			-O2 -g
CMAKE_C_COMPILER					c:/msys/mingw/bin/gcc.exe
CMAKE_C_FLAGS					''
CMAKE_C_FLAGS_DEBUG					-g
CMAKE_C_FLAGS_MINSIZEREL				-Os -DNDEBUG
CMAKE_C_FLAGS_RELEASE				-O3 -DNDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO			-O2 -g
CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_INSTALL_PREFIX					C:/Programmi/qgis0.9.2
CMAKE_MAKE_PROGRAM					c:/msys/mingw/bin/mingw32-make.exe
CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_RANLIB						c:/msys/mingw/bin/ranlib.exe
CMAKE_SH						CMAKE_SH-NOTFOUND
CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SKIP_RPATH					OFF
CMAKE_USE_RELATIVE_PATHS				OFF
CMAKE_VERBOSE_MAKEFILE				OFF
ENABLE_TESTS						OFF
EXECUTABLE_OUTPUT_PATH				OFF
EXPAT_INCLUDE_DIR					c:/msys/local/include
EXPAT_LIBRARY						c:/msys/local/bin/libexpat.dll.a
FLEX_EXECUTABLE					C:/msys/local/bin/fles.exe
GDAL_INCLUDE_DIR					c:/msys/local/include
GDAL_LIBRARY						c:/msys/local/lib/libgdal.dll
GEOS_INCLUDE_DIR					c:/msys/local/include
GEOS_LIBRARY						c:/msys/local/lib/libgeos.dll.a
GRASS_INCLUDE_DIR					GRASS_INCLUDE_DIR-NOTFOUND
GRASS_PREFIX
GSLCBLAS_LIB						c:/msys/local/lib/libgslcblas.a
GSL_INCLUDE_DIR					c:/msys/local/include
GSL_LIB							c:/msys/local/lib/libgsl.a
LIBRARY_OUPUT_PATH
LIB_PATH						LIB_PATH-NOTFOUND
PEDANTIC						OFF
POSTGRES_INCLUDE_DIR					POSTGRES_INCLUDE_DIR-NOTFOUND
POSTGRES_LIBRARY					POSTGRES_LIBRARY-NOTFOUND
PROJ_INCLUDE_DIR					c:/msys/local/include
PROJ_LIBRARY						c:/msys/local/bin/libproj.dll
PYTHON_DEBUG_LIBRARY				PYTHON_DEBUG_LIBRARY-NOTFOUND
PYTHON_EXECUTABLE					c:/Programmi/Python.exe
PYTHON_INCLUDE_PATH					c:/Programmi/Python/include
PYTHON_LIBRARY					c:/Programmi/Python/libs/libpython25.a
QGIS_BIN_SUBDIR					.
GGIS_DATA_SUBDIR					.
QGIS_INCLUDE_SUBDIR					include
QGIS_LIB_SUBDIR					.
QGIS_PLUGIN_SUBDIR					plugins
QT_DOC_DIR						C:/Qt/4.3.3/doc
QT_INCLUDE_DIR						C:/Qt/4.3.3/include
QT_LIBRARY_DIR						C:/Qt/4.3.3/lib
QT_LRELEASE_EXECUTABLE				C:/Qt/4.3.3/bin/lrelease.exe
QT_MKSPECS_DIR					C:/Qt/4.3.3/mkspecs
QT_MOC_EXECUTABLE					C:/Qt/4.3.3/bin/moc.exe
QT_PLUGINS_DIR						C:/Qt/4.3.3/plugins
QT_QMAKE_EXECUTABLE					C:/Qt/4.3.3/bin/qmake.exe
QT_QT3SUPPORT_INCLUDE_DIR				C:/Qt/4.3.3/include/Qt3Supprt
QT_QT3SUPPORT_LIBRARY				C:/Qt/4.3.3/lib/libQt3Support4.a
QT_QT3SUPPORT_LIBRARY_DEBUG			QT_QT3SUPPORT_LIBRARY_DEBUG-NOTFOUND
QT_QT3SUPPORT_LIBRARY_RELEASE			C:/Qt/4.3.3/libQt3Support4.a
QT_QTASSISTANT_INCLUSE_DIR				C:/Qt/4.3.3/include/QtAssistant
QT_QTASSISTANT_LIBRARY				C:/Qt/4.3.3/lib/libQtAssistantClient4.a
QT_QTASSISTANT_LIBRARY_DEBUG			QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND
QT_QTASSISTANT_LIBRARY_RELEASE			C:/Qt/4.3.3/lib/libQtAssistantClient4.a
QT_QTCORE_INCLUDE_DIR				C:/Qt/4.3.3/include/QtCore
QT_QTCORE_LIBRARY					C:/Qt/4.3.3/lib/libQtCore4.a
QT_QTCORE_LIBRARY_DEBUG				QT_QTCORE_LIBRARY_DEBUG-NOTFOUND
QT_QTCORE_LIBRARY_RELEASE				C:/Qt/4.3.3/lib/libQtCore4.a
QT_QTDESIGNER_INCLUDE_DIR				C:/Qt/4.3.3/include/QtDesigner
QT_QTDESIGNER_LIBRARY				C:/Qt/4.3.3/lib/libQtDesigner4.a
QT_QTDESIGNER_LIBRARY_DEBUG				QT_QTDESIGNER_LIBRARY_DEBUG-NOTFOUND
QT_QTDESIGNER_LIBRARY_RELEASE			C:/Qt/4.3.3/lib/libQtDesigner4.a
QT_QTGUI_INCLUDE_DIR					C:/Qt/4.3.3/include/QtGui
QT_QTGUI_LIBRARY					C:/Qt/4.3.3/lib/libQtGui4.a
QT_QTGUI_LIBRARY_DEBUG				QT_QTGUI_LIBRARY_DEBUG-NOTFOUND
QT_QTGUI_LIBRARYRELEASE				C:/Qt/4.3.3/lib/libQtGui4.a
QT_QTMAIN_LIBRARY					C:/Qt/4.3.3/lib/libqtmain.a
QT_QTMAIN_LIBRARY_DEBUG				QT_QTMAIN_LIBRARY_DEBUG-NOTFOUND
QT_QTMAIN_LIBRARY_RELEASE				C:/Qt/4.3.3/lib/libqtmain.a
QT_QTNETWORK_INCLUDE_DIR				C:/Qt/4.3.3/include/QtNetwork
QT_QTNETWORK_LIBRARY				C:/Qt/4.3.3/lib/libQtNetwork4.a
QT_QTNETWORK_LIBRARY_DEBUG				QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND
QT_QTNETWORK_LIBRARY_RELEASE			C:/Qt/4.3.3/lib/libQtNetwork4.a
QT_QTNSPLUGIN_INCLUDE_DIR				QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_DEBUG				QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_RELEASE			QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
QT_QTOPENGL_INCLUDE_DIR				C:/Qt/4.3.3/include/QtOpenGL
QT_QTOPENGL_LIBRARY					C:/Qt/4.3.3/lib/libQtOpenGL4.a
QT_QTOPENGL_LIBRARY_DEBUG				QT_QTOPENGL_LIBRARY_DEBUG	-NOTFOUND
QT_QTOPENGL_LIBRARY_RELEASE			C:/Qt/4.3.3/lib/libQtOpenGL4.a
QT_QTSQL_INCLUDE_DIR					C:/Qt/4.3.3/include/QtSql
QT_QTSQL_LIBRARY					C:/Qt/4.3.3/lib/libQtSql4.a
QT_QTSQL_LIBRARY_DEBUG				QT_QTSQL_LIBRARY_DEBUG-NOTFOUND
QT_QTSQL_LIBRARY_RELEASE				C:/Qt/4.3.3/lib/libQtSql4.a
QT_QTSVG_INCLUDE_DIR					C:/Qt/4.3.3/include/QtSvg
QT_QTSVG_LIBRARY					C:/Qt/4.3.3/lib/liQtSvg4.a
QT_QTSVG_LIBRARY_DEBUG				QT_QTSVG_LIBRARY_DEBUG-NOTFOUND
QT_QTSVG_LIBRARY_RELEASE				C:/Qt/4.3.3/lib/libQtSvg4.a
QT_QTTEST_INCLUDE_DIR					C:/Qt/4.3.3/include/QtTest
QT_QTTEST_LIBRARY					C:/Qt/4.3.3/lib/libQtTest4.a
QT_QTTEST_LIBRARY_DEBUG				QT_QTTEST_LIBRARY_DEBUG-NOTFOUND
QT_QTTEST_LIBRARY_RELEASE				C:/Qt/4.3.3/lib/libQtTest4.a
QT_QTUITOOLS_INCLUDE_DIR				C:/Qt/4.3.3/include/QtUiTools
QT_QTUITOOLS_LIBRARY					C:/Qt/4.3.3/lib/libQtUiTools.a
QT_QTUITOOLS_LIBRARY_DEBUG				QT_QTUITOOLS_LIBRARY_DEBUG-NOTFOUND
QT_QTUITOOLS_LIBRARY_RELEASE			C:/Qt/4.3.3/lib/libQtUiTools.a
QT_QTXML_INCLUDE_DIR					C:/Qt/4.3.3/include/QtXml
QT_QTXML_LIBRARY					C:/Qt/4.3.3/lib/libQtXml4.a
QT_QTXML_LIBRARY_DEBUG				QT_QTXML_LIBRARY_DEBUG-NOTFOUND
QT_QTXML_LIBRARY_RELEASE				C:/Qt/4.3.3/lib/libQtXml4.a
QT_QT_INCLUDE_DIR					C:/Qt/4.3.3/include/Qt
QT_RCC_EXECUTABLE					C:/Qt/4.3.3/bin/rcc.exe
QT_UIC3_EXECUTABLE					C:/Qt/4.3.3/bin/uic3.exe
QT_UIC_EXECUTABLE					C:/Qt/4.3.3/bin/uic.exe
SIP_BINARY_PATH					C:/Programmi/Python/sip.exe
SIP_INCLUDE_DIR						C:/Programmi/Python/include
SQLITE3_INCLUDE_DIR					c:/msys/local/include
SQLITE3_LIBRARY					c:/msys/local/lib/sqlite3.dll
SVA_MARKER						C:/dev/cpp/qgis/.svn/entries
WINDRES						c:/msys/mingw/bin/windres.exe
WITH_BINDINGS						ON
WITH_GRASS						ON
CMAKE_BUILD_TYPE
GRASS_PREFIX
LIBRARY_OUPUT_PATH
