AW: Re: [Qgis-developer] Better Menus for QGIS 1.0
Düster Horst
Horst.Duester at bd.so.ch
Tue Jul 1 02:16:20 EDT 2008
+1
> Developers,
> As we approach QGIS 1.0, I would like to see a menu overhaul both to
> make QGIS more accessible to new users and to bring QGIS into
> compliance with Apple standards. I will prepare a revised menu
> design and implement it if the general concept is acceptable. If any
> Mac standard conflicts with other platform standards, I will
> conditionalize these differences just for a Mac.
> 1. The menu system should be somewhat like a table of contents. When
> I first use an unfamiliar application, I check the capabilities by
> scanning through all the menus. If I don't find a menu item with a
> phrase related to the task I hope to accomplish, I conclude that the
> application doesn't do it. At present, some QGIS functionality is
> accessible only though toolbars and context menus. A new user
> shouldn't have to guess the meaning of icons or where to click to
> get a context menu even though these make great shortcuts for
> initiated users.
> The Mac also has a Hide/Show Toolbar window control. An application
> should be fully functional when toolbars are hidden. Apple's Human
> Interface Guidelines says "Make sure that every toolbar item you
> create has an associated menu command."
> 2. Every QGIS window should have an associated menu bar, either the
> main menu bar or its own menu bar. The application menu bar is
> displayed across the top of the screen on a Mac; this space becomes
> blank when there isn't an associated menu. At present, Print
> Composer and Attribute Table windows have no menu bar.
> 3. There is no Window menu and windows get lost below other windows.
> Although it's a bug, some already open QGIS windows don't move
> forward when the command to open them is invoked again; a Window
> menu would let you know what's open. There is also no Edit menu; the
> highlight state of the Copy/Paste menu items should provide a clue
> for where these functions are or aren't available.
> Apple's HIG says: The menu bar ... is always visible and
> available ... Always contains ... a Window menu ... contain the
> following menus, if they make sense in your application ... an Edit
> menu"
> Moving beyond these Mac usability issues, I would also like to see
> consistency between menus and toolbars. For example, the File menu
> uses the order New, Open, Save while the File toolbar uses New,
> Save, Open. I find this confusing. A similar oddity is that New
> Layer is in the Layer toolbar but Add Layer is in the File toolbar.
> Combining two menus into one toolbar might make sense but having two
> almost corresponding menus and toolbars where a few items are in one
> menu but the other toolbar is also confusing.
> Now that the feature set for QGIS 1.0 is fixed, I think we should
> take the opportunity to review and organize all existing commands.
> What do others think?
> Tom
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080701/18c1d680/attachment-0001.html
