[Qgis-developer] no Polish chars in table, labels, query results!
Maciej Sieczka
tutey at o2.pl
Tue Jul 1 16:56:20 EDT 2008
Maciej Sieczka pisze:
> Marco Hugentobler pisze:
>> If you think it is a QGIS related problem, then it is probably best
>> to check out a revision from a couple of weeks ago as you suggest:
>> svn co --revision {yyyy-mm-dd}
> OK. I'll try.
The last QGIS SVN trunk revision which display Polish chars correctly is
r8591. r8592 is when things went funky. Jürgen was the author.
Maciek
Maciej Sieczka
www.sieczka.org
