[Qgis-developer] plugins
Tim Sutton tim at linfiniti.com
Mon Jul 7 10:00:50 EDT 2008
Hi Borys
I downloaded and tested your plugin today and its working well for me
in the basic testing I did. But since you are still working on this
and we have issues like how to distribute python plugins with QGIS
which have not been worked on, I think we are going to need to leave
integrating your plugin manager for then 1.0 release since I need to
branch for release as soon as possible now, and I would prefer your
manager gets well tested before putting it into the release.
Is this ok for everyone?
By the way well done - the user interface is very clean and neat!
Regards
Tim
2008/7/2 Borys Jurgiel <borys at wolf.most.org.pl>:
> Wednesday 02 of July 2008 00:11:09 Paolo Cavallini napisał(a):
>> I finally did some more testing on plugins. I like very much the new
>> installer. One possible improvement: why not letting the user choose
>> whether to activate each plugin, without having to go to the plugin
>> manager menu? Furthermore,
>> I did not succeed installing the following:
>> - generate Voronoi polygons, LoadLayer, ManageR (This plugin seems to be
>> broken or have unfilled dependencies): it would be good to tell the user
>> what to do in these cases (install python-rpy)
> Thanks! Sorry I didn't give an account of works on Installer last weeks, but
> I'm working on it nearly every day so it's changing from day to day, as you
> can see if you have it installed. I'll write something more in the next days.
> I'm not sure if there's any way for activating plugins directly from the
> Installer, however I'll try to find it when all the major features will be
> done.
>> - spatial operations (by tgwong, Official repo): it shows "upgradable"
>> but it does not upgrade (yes, I miss shapely).
> This is because the Authors often forget about updating both declarations of
> the version number: in the repository and in the plugin. In this case, the
> plugin has the internal number declared as 0.1 and in the repository it's
> declared as 0.2. So you can install it time after time and the Installer
> still sees version 0.1 installed and 0.2 available.
> I'll add a workaround to the Installer for "downgrading" the available version
> from 0.2 to 0.1, as it is done with several plugins already. So you won't see
> this particular upgrade, but at least the Installer will be quiet ;)
>> Moreover, there is a line
>> citing a readme file as a plugin (with broken dependencies).
> It's because the readme file is outside the plugin directory. The Installer
> reports and lets to remove all such "strange" files. I'll contact the Author
> and ask for correcting it.
> Qgis-developer mailing list
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
