[Qgis-developer] QGIS 0.11.0 'Metis' - Call for packaging
William Kyngesburye
woklist at kyngchaos.com
Tue Jul 15 16:17:04 EDT 2008
On Jul 13, 2008, at 7:20 PM, Tim Sutton wrote:
> Hi Folks (and especially package makers and release team)
> Tonight I created the release branch (revision 8769) for 0.11.0 Metis:
> svn co https://svn.osgeo.org/qgis/branches/Release-0_11_0
Tom,
My build on Leopard worked, but I have an error for Tiger. I'm
building on Leopard, using the 10.4 SDK to build for Tiger.
OSX 10.5.3
Xcode 3.1
Qt 4.3.5
I don't have handy access to a Tiger system with an older Xcode to see
if it's a problem in the 10.4 the SDK. (I have one at work, but it's
busy) Do you still build on Tiger? Any problems? I might be able to
try at work in a couple days.
Here is the error:
Scanning dependencies of target qgis
[ 39%] Building CXX object src/app/CMakeFiles/qgis.dir/main.o
/usr/bin/c++ -arch ppc -arch i386 -isysroot /Developer/SDKs/
MacOSX10.4u.sdk -O3 -DNDEBUG -DQT_NO_DEBUG -I/Library/Frameworks/
QtSvg.framework/Headers -I/Library/Frameworks/QtGui.framework/Headers -
I/Library/Frameworks/QtXml.framework/Headers -I/Library/Frameworks/
QtSql.framework/Headers -I/Library/Frameworks/QtNetwork.framework/
Headers -I/Library/Frameworks/QtCore.framework/Headers -I/Users/Shared/
src/qgis/svn/qgis-0.11.0/build-tig -I/Users/Shared/src/qgis/svn/
qgis-0.11.0/src/app -I/Users/Shared/src/qgis/svn/qgis-0.11.0/src/app/
composer -I/Users/Shared/src/qgis/svn/qgis-0.11.0/src/app/legend -I/
Users/Shared/src/qgis/svn/qgis-0.11.0/build-tig/src/app -I/Users/
Shared/src/qgis/svn/qgis-0.11.0/build-tig/src/app/../ui -I/Users/
Shared/src/qgis/svn/qgis-0.11.0/src/app/../core -I/Users/Shared/src/
qgis/svn/qgis-0.11.0/src/app/../core/raster -I/Users/Shared/src/qgis/
svn/qgis-0.11.0/src/app/../core/renderer -I/Users/Shared/src/qgis/svn/
qgis-0.11.0/src/app/../core/symbology -I/Users/Shared/src/qgis/svn/
qgis-0.11.0/src/app/../gui -I/Users/Shared/src/qgis/svn/qgis-0.11.0/
src/app/../plugins -I/Users/Shared/src/qgis/svn/qgis-0.11.0/src/app/../
python -I/Library/Frameworks/PROJ.framework/Headers -I/Library/
Frameworks/SQLite3.framework/Headers -I/Library/Frameworks/
geos.framework/unix/include -I/Library/Frameworks/GDAL.framework/
Headers -I/usr/local/pgsql/include -F/Library/Frameworks -L/Library/
Frameworks -DQT_SHARED -DQT_SVG_LIB -DQT_GUI_LIB -DQT_XML_LIB -
DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_NO_CAST_TO_ASCII -
DCORE_EXPORT= -DGUI_EXPORT= -DPYTHON_EXPORT= -F/Library/Frameworks -F/
System/Library/Frameworks -o src/app/CMakeFiles/qgis.dir/main.o -c /
Users/Shared/src/qgis/svn/qgis-0.11.0/src/app/main.cpp
In file included from /System/Library/Frameworks/
CoreServices.framework/Frameworks/CFNetwork.framework/Headers/
CFNetwork.h:27,
CoreServices.framework/Headers/CoreServices.h:37,
ApplicationServices.framework/Headers/ApplicationServices.h:20,
from /Users/Shared/src/qgis/svn/qgis-0.11.0/src/app/
main.cpp:61:
/System/Library/Frameworks/CoreServices.framework/Frameworks/
CFNetwork.framework/Headers/CFNetworkErrors.h:27:26: error:
Availability.h: No such file or directory
CFNetwork.h:27,
main.cpp:61:
/System/Library/Frameworks/IOKit.framework/Headers/
OSMessageNotification.h:85: error: ‘io_user_reference_t’ was not
declared in this scope
OSMessageNotification.h:87: error: ‘io_user_reference_t’ does not name
a type
OSMessageNotification.h:92: error: ‘OSAsyncReference64’ does not name
a type
OSMessageNotification.h:103: error: ‘io_user_reference_t’ does not
name a type
... and more
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
