[Qgis-developer] QGIS 0.11.0 'Metis' - Call for packaging
William Kyngesburye
woklist at kyngchaos.com
Wed Jul 16 09:12:51 EDT 2008
On Jul 16, 2008, at 1:19 AM, Tom Elwertowski wrote:
> William,
> Building on 10.4 for 10.4 works for me.
> Your problem appears to be the same one Gary encountered back in
> April. It's caused by the FIND_LIBRARY ApplicationServices in the
> top level CMakeLists.txt. It adds -F/System/Library/Frameworks to
> the command line and this searches the real /System even though -
> isysroot is specified. It picks up a 10.5 header and then tries to
> find additional headers in the 10.4 sdk.
> A hack fix is to add the prefix /Developer/SDKs/MacOSX10.4u.sdk to
> the path
> APP_SERVICES_LIBRARY:FILEPATH=/System/Library/Frameworks/
> ApplicationServices.framework
> in CMakeCache.txt.
> An alternative hack is to replace FIND_LIBRARY( APP_SERVICES_LIBRARY
> ApplicationServices)
> in the root CMakeLists.txt with
> SET( APP_SERVICES_LIBRARY "-framework ApplicationServices")
I don't think the -F/System/Library/Frameworks should ever be needed.
This is always in the default search path for frameworks (as well as /
Library/Frameworks). And whether or not you use the system or an SDK,
-framework SomeSystemFramework will find it in the right place, and
any internal includes in those frameworks will work.
And, those extra -L/System/Library/Frameowkrs and -L/Library/
Frameworks are pointless as well, whereever they are coming from.
> I just noticed that CMake 2.4 generates the -F/System/Library/
> Frameworks but 2.6 doesn't. Upgrading Cmake may be the solution.
So, Cmake 2.6 does it right. It realizes that the system frameworks
don't need -F.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
