[Qgis-developer] Error compiling from trunk - unknown
QStyle::PE_PanelItemViewItem
Borys Jurgiel
borys at wolf.most.org.pl
Thu Jul 17 03:54:16 EDT 2008
Wednesday 16 of July 2008 22:51:48 Tim Sutton napisał(a):
> Hi Borys
> An issue like this was reported on IRC earlier today which I committed
> a fix for (r8792) . I see Jurgen also submitted a fix. Could you
> confirm if the issue still exists. Also check if qgis binary is linked
> to the correct libraries (e.g. libgqgis 11 and not another version).
Right, my fault! It was due to the old 0.11 libraries. After removing them,
everything works. But I still worry, why QGIS tried to use the 0.11 libs
whereas there were links to the proper 1.0 libs.
