[Qgis-developer] C++ vs C API
Jürgen E. Fischer
jef at norbit.de
Mon Jul 21 04:52:43 EDT 2008
Hi Paolo,
On Mon, 21. Jul 2008 at 10:39:17 +0200, Paolo Cavallini wrote:
> AFAIK, C++ API support was recently removed by FrankW in favour of the
> more stable C support.
That's just the GDAL API. We still use the GEOS C++ API.
> This should have removed the need of recompiling qgis+gdal at every
> new version, but this does not appear the case (in deb, for instance,
> qgis crashes at startup with new gdal, unless one recompiles it
> without optimization). Am I missing something? Or did C++ interface
> crept in sometimes?
I don't think the GDAL issue is a ABI problem. The ABI shouldn't change
if you compile with or without optimization. And should also only be a
problem when you mix binaries produced by different compiler (versions).
I suspect that this is a more general GCC 4.3 optimization problem -
IIRC Debian also currently compiles mapserver w/o optimization on GCC
4.3, because of that.
BTW did you verify that on platforms other than amd64?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
