[Qgis-developer] Plugin Installer
Borys Jurgiel
borys at wolf.most.org.pl
Mon Jul 21 14:36:55 EDT 2008
> - where do we put it in svn tree
> - where do we install it to
> - assuming we install to a sys dir e.g. under /usr/... , do we plan
> to mask out sys plugins if the same plugin is installes in users home
> dir
That is what QGIS does now. It is simple and sufficient for upgrading the
plugins, as I think. So just replacing the old installer will be big
advantage with low effort.
> - assuming yes above, do we give version precedence to newer versions
> regardless of location
I wondered about this. I think it would be nice, but is not necessary if we
can keep the main repo up to date. Finally, there are only two plugins in the
sys location and a lot of other things to do for 1.0 ;)
But if you want this functionality, I've wrote a version compare function in
Python (I haven't found nothing appropriate), so we can use this idea in
qgspythonutilsimpl.cpp.
> Probably there are more issues we should also consider. Martin would
> be the right person to manage this integration process but I'm not
> sure when he will be back in hack mode.
Unfortunatelly, he told something about two months...
Regards
