[Qgis-developer] QgsPoint as a python list
Stefanie Tellex
stefie10 at media.mit.edu
Tue Jun 3 08:54:33 EDT 2008
This patch (against r8576) extends the QgsPoint python interface so it
can act like a two element immutable python list. This makes idioms
the following possible:
x, y = point
I also write a lot of code that assumes points are tuples, and with this
patch I can pass QgsPoints to those methods without any conversion
code.
Stefanie
(PS: Sorry for sending all these patches at once. I had a problem
applying my patch stream to the latest revision of qgis and I was too
busy to fix it for a while... )
Index: qgis/qgis_unstable/python/core/qgspoint.sip
--- qgis.orig/qgis_unstable/python/core/qgspoint.sip 2008-06-02 12:54:53.000000000 -0400
+++ qgis/qgis_unstable/python/core/qgspoint.sip 2008-06-02 12:57:20.000000000 -0400
@@ -82,6 +82,39 @@
sipRes = PyString_FromString(str.toLocal8Bit().data());
%End
+ int __len__();
+%MethodCode
+ sipRes = 2;
+%End
+ SIP_PYOBJECT __getitem__(int);
+%MethodCode
+ if (a0 == 0) {
+ sipRes = Py_BuildValue("d",sipCpp->x());
+ } else if (a0 == 1) {
+ sipRes = Py_BuildValue("d",sipCpp->y());
+ } else {
+ QString msg = QString("Bad index: %1").arg(a0);
+ PyErr_SetString(PyExc_IndexError, msg.toAscii().constData());
+%End
+ void __setitem__(int, double);
+%MethodCode
+ if (a0 == 0) {
+ sipCpp->setX(a1);
+ sipCpp->setY(a1);
+ } else {
+%End
}; // class QgsPOint
