[Qgis-developer] [Mac OSX] Build error with CMake 2.6
Tom Elwertowski telwertowski at comcast.net
Fri Jun 6 03:08:08 EDT 2008
Tom Elwertowski wrote:
> CMake 2.4 and 2.6 appear somewhat incompatible, at least for Macs.
> Regarding Contents/CMakeLists.txt, I am baffled by the quote processing.
I upgraded the Mac Info.plist generation process to use a cmake script containing CONFIGURE_FILE rather running grep/sed. Magnus Homann improved the generation of qgssvnversion.h by doing this awhile ago. Using the same technique for inserting the svn revision number here avoids solving the CMake 2.6 quoting mystery.
Tom
> Tim Sutton wrote:
>> Hi Folks
>> I've been testing out CMake 2.6.0 which recently came out. On mac I
>> get everything to build except it croaks at the end with this:
>> Linking CXX shared module libquickprintplugin.so
>> [100%] Built target quickprintplugin
>> /bin/sh: -c: line 1: unexpected EOF while looking for matching ``'
>> /bin/sh: -c: line 2: syntax error: unexpected end of file
>> make[2]: *** [src/mac/Contents/CMakeFiles/Info.plist] Error 2
>> make[1]: *** [src/mac/Contents/CMakeFiles/Info.plist.dir/all] Error 2
>> make: *** [all] Error 2
>> It seems it has  problem parsing the bash commands in the src/mac/
>> Contents/CMakeLists.txt. Is this something you are easily able to fix
>> Tom? I had a poke at it but all I can figure out is that cmake seems
>> to be wrapping the expression in "" or something, but I couldnt
>> figure out how to resolve the issue.
>> Regards
> Qgis-developer mailing list
