[Qgis-developer] calling createEmptyDataSource from python
Stefanie Tellex
stefie10 at media.mit.edu
Fri Jun 6 17:32:31 EDT 2008
Hi Martin,
I didn't know about QgsVectorFileWriter. How come qgisapp.cpp doesn't
use it to create a new layer? I was looking there to figure out how to
make a new empty data source, and saw it was doing fancy stuff to call
createEmptyDataSource in the ogr library.
I think my patch is better for three reasons:
* It seems like it would be more work to call QgsVectorFileWriter
from python than it would be to use the patch I submitted to call
createEmptyDataSource from python. With the patch I submitted,
createEmptyDataSource gets passed a list of tuples specifying the
fields, while QgsVectorFileWriter wants a QgsFieldMap, and has to be
opened and closed to save the shapefile.
* my patch refactors createEmptyDataSource into a function in
QgsVectorDataProvider, which cleans up the code in qgisapp, makes it
easier to change qgis app to use createEmptyDataSource with other
providers, and makes it so python and qgisapp use the same mechanism for
making new empty data sources.
* createEmptyDataSource not only makes file.shp, but also file.dbf,
file.prj, and file.shx. I don't know what they are, but they sound
important. :-)
Thanks,
Stefanie
Martin Dobias wrote:
> On Thu, Jun 5, 2008 at 4:34 AM, Stefanie Tellex <stefie10 at media.mit.edu> wrote:
>> Hi,
>> Is there a way to call the ogr provider's createEmptyDataSource function
>> from python? I could try using ctypes, but I wasn't sure if it would work
>> with the sip interface. Combining two ways of talking to C/C++ from python
>> seems hairy.
> Hi Stefanie,
> what about using QgsVectorFileWriter instead? Or is there anything
> that you'd like to use and it's not available?
> Bye
> Martin
