[Qgis-developer] WMS-Proxy settings broken?
Stephan Holl stephan.holl at intevation.de
Mon Jun 16 02:56:12 EDT 2008
Hello Tim,
"Tim Sutton" <tim at linfiniti.com>, [20080616 - 00:36:26]
> Hi Stephan and others
> Ok Ive implemented proxy support as an application global setting in
> r8649.
Wow, excellent news! I will give it a go tonight and report back.
> It required some small changes to raster api so I hope it does
> not interfere with any / many existing python plugins out there. Now I
> need someone with a proxy to test it and tell me if its all working
> ok....
I will let you know what my testing did.
Best
	Stephan
> Best regards
> Tim
> 2008/6/11 Stephan Holl <stephan.holl at intevation.de>:
> > Hello Tim,
> > "Tim Sutton" <tim at linfiniti.com>, [20080611 - 14:24:37]
> >> Hi guys
> >> Marco ok thanks for the  clarificatio - I'll try to implement proxy
> >> settings centralisation over the next few days so leave it to me. i
> >> dont think its the qt3 port that is the cause of the issue if the
> >> problem is present in 0.10.0 too. Stephan QGIS 0.11.0 will be out
> >> at the end of the month so I dont expect to backport any fixes to
> >> 0.10.0.
> > No problem. I just wanted to make sure that proxy-settings will be
> > repaired in the next release, and if it will be centralized, even
> > better! This makes the project-files more transportable though.
> > Thanks Tim for the offer to implement it befor 0.11.0. I am happy to
> > give you feedback when you have included it.
> > Since I heavily use QGIS
> > through a security-proxy[1] to access secured WMS/WFS I need the
> > proxy-settings in QGIS, because it does not reflect the environment
> > variables http_proxy/https_proxy.
> > Best
> >        Stephan
> > [1] http://inteproxy.wald.intevation.org
> >> On 6/11/08, Stephan Holl <stephan.holl at intevation.de> wrote:
> >> > Hallo Marco, Tim,
> >> > "Hugentobler  Marco" <marco.hugentobler at karto.baug.ethz.ch>,
> >> > [20080611
> >> > - 10:49:17]
> >> >> Hi,
> >> >> I only changed the plugin interface, not the WMS dialog/provider
> >> >> itself. Afaik, there have been some ui changes in the WMS
> >> >> dialog to remove qt3 compatibility classes.
> >> >> Centralizing the proxy stuff in options, as suggested by Tim,
> >> >> is a good idea. I haven't started with this and I'm quite busy
> >> >> at the moment, so if someone feels like implementing this, it
> >> >> would be very welcome.
> >> > Yes, this is definitely a good idea, but some of my clients do
> >> > need the proxy-settings for WMS, it would be good to provide a
> >> > fix (since it is broken in 0.10.0 as well) for the current
> >> > version though.
> >> > Best regards
> >> >     Stephan
> >> > Stephan Holl <stephan.holl at intevation.de>,
> >> > http://intevation.de/~stephan Tel: +49 (0)541-33 50 8 32 |
> >> > Intevation GmbH | AG Osnabrück - HR B 18998 Geschäftsführer:
> >> > Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
> > Intevation GmbH | AG Osnabrück - HR B 18998 Geschäftsführer:  Frank
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
