[Qgis-developer] Problem in shapefiles rendering
Martin Dobias
wonder.sk at gmail.com
Mon Jun 16 17:53:58 EDT 2008
sorry but with this amount of information really none can help you.
What exactly are you trying to do? Is it some QGIS-based application?
Why don't you use directly map canvas? Some more code to see what
actually is happening?
Martin
On Tue, Jun 10, 2008 at 8:20 AM, bargi john <bargi1981 at gmail.com> wrote:
> Hi all,
> I am trap in a strange problem while rendering shapefiles.
> I am used some code of [quote]qgsmapcanvas.cpp [/quote] for creating
> Graphicsview and QGraphicsScene.
> The code I have wrote is as follow:
> [code]
> View::View( QWidget *parent ): QGraphicsView( parent )
> m_scene = new QGraphicsScene();
> setScene( m_scene );
> setRenderHint( QPainter::Antialiasing );
> setMouseTracking( true );
> setFrameShadow( QFrame::Sunken );
> setFrameShape ( QFrame::Panel );
> [/code]
> The m_scene set here is used in other CPP file where items are added to
> scene. The code is as follow:
> [code]
> QGraphicsScene *Draw::scene() const
> return m_scene; // This object is same as set in View.cpp
> void Draw::render()
> .........// logic to extract items
> m_scene->addItem( item ); //Here item is QGraphicsItem
> [/code]
> The problem is that only point Shapfiles are drawing correctly.
> The line and polygon shapefiles are drawn as inverted.
> If I put clutch using [quote]scale(1,-1) [/quote] then it draw line and
> polygon correct but point shapefiles inverted.
> Can any body explain me this strange behavior and solution to it.
> Thanks :(
> Qgis-developer mailing list
