[Qgis-developer] Re: composer redesign branch
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Tue Mar 4 10:01:23 EST 2008
Am Dienstag 04 März 2008 02:06:49 schrieb Martin Dobias:
> On Mon, Mar 3, 2008 at 5:45 PM, Marco Hugentobler
> <marco.hugentobler at karto.baug.ethz.ch> wrote:
> > So my suggestion is to have the rendering context somehow like this:
> > class QgsMapRenderContext
> > QgsMapToPixel mMapToPixel;
> > QgsCoordinateTransform mCoordTransform;
> > QgsRect mExtent;
> > bool drawEditingInformation;
> > bool mRenderingStopped;
> > double mResolutionRatio;
> Yes, something like that should do it...
> We should also include a member like "force vector output" which will
> tell to renderer whether it can use just a rendered pixmap of a symbol
> or whether it should render the symbol directly - this is where map
> composer is failing.
A possibility would be to force vector output if mResolution is != 1.0. But
it may be better to make that explicitly and not depending on resolution as
you suggest.
> > The resolution ratio is usually 1, except when drawing to a different
> > paint device (like QPrinter). I hope it will allow to consider for
> > different line width / symbol sizes on these output devices.
> When looking at QgsVectorLayer::draw(), there's symbolScale and
> widthScale... are both of them covered by mResolutionRatio?
I'm not sure. In principle, one should be enough for symbol and width scaling
as both are dependent on resolutions.
So I'm waiting a few days for any further input or objections, then I'm going
to create the branch.
cheers,
Marco
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
