[Qgis-developer] Re: [Qgis-user] vector editing in QGIS - questions and issues (PostGIS biased)
Maciej Sieczka tutey at o2.pl
Wed Mar 5 11:24:23 EST 2008
Marco Hugentobler pisze:
> Am Dienstag 04 März 2008 20:28:56 schrieb Maciej Sieczka:
>>> I changed the behaviour now such that the snapping settings is only
>>> changed if the user really opened the project snapping dialog and clicked
>>> 'ok'.
>> Do you mean you submitted it to SVN? I'm asking because I can't see it
>> in the commit ML.
> Yes, in r8189. The commit ML is sometimes slow.
OK. Fetched it and built OK. It is better this way now. Still not as
convenient as it could be though - once OK in Snapping Options is
clicked, the Default Snapping looses it's purpose until a new project is
started. It is confusing that the user can still modify Default
Snapping, while it has no effect.
This could be easily fixed I guess. Please read below.
>> Before I think of it again, can you please first let me know if the two
>> in "Snapping options":
>> 1. tolerance set to 0 and the layer checked
>> 2. tolerance set to anything and the layer not checked
>> result both in snapping disabled? I guess they are supposed to, but want
>> to make sure.
> Yes, it has the same effect. At the moment, disabling is a bit more efficient.
> But in principle, that could also be done for snapping tol 0 by adding a
> query earlier in the code.
Got it.
> In my opinion, the advantage of the check boxes is that it is
> possible to disable the snapping during digitising without
> overwriting the previous settings (e.g. during a certain stage of
> digitising). Then, it can be quickly enabled by selecting the box again.
You are right.
Thinking it all over again, I imagine the whole thing this way now:
In Options > Digitizing > Default Snapping give it a "mode" selector and
a checkbox (alike Project Properties > Snapping Options). These settings
are stored in QGIS preferences file. Until Default Snapping *is
checked*, it takes precedence over individual layer's settings, thus
it's enabled for *all* layers, in any project.
Modifying individual snapping of a layer, through Project Properties >
Snapping Options, is not possible then - layers are greyed-out in the
dialog. The latter is also a signal for the user that global snapping
setting is enabled, and he should turn it off to be able to tweak
snapping per layer.
If Options > Digitizing > Default Snapping *is not checked*, modifying
individual snapping Project Properties > Snapping Options for any layer
becomes possible, and this setting takes precedence over the default.
Opinions? Could this be implemented?
Maciek
