[Qgis-developer] Problem with python bindings
Carlos Dávila
cdavilam at jemila.jazztel.es
Wed Mar 5 11:49:12 EST 2008
Martin Dobias escribió:
> On Tue, Mar 4, 2008 at 5:49 PM, Carlos Dávila
> <cdavilam at jemila.jazztel.es> wrote:
>> > Can you tak a look to the python/core and python/gui directories in
>> > the svn checkout? Do you see only .sip files or are there also
>> > core.sbf resp. gui.sbf files?
>> Only .sip files in both directories.
> So this looks like python configure script or SIP binary fail to run
> correctly. Try this: go to your build directory, enter python subdir.
> There you should find configure.py script. In console run: python
> configure.py
> Does it report any error?
This is what I get:
~/Paquetes/qgis/0.9.2/build/python$ python configure.py
Parsing SIP files for 'core' library...
sip: Usage: sip [-h] [-V] [-a file] [-c dir] [-d file] [-e] [-g] [-I
dir] [-j #] [-m file] [-p module] [-r] [-s suffix]
[-t tag] [-w] [-x feature] [-z file] [fi le]
Parsing SIP files for 'gui' library...
Creating makefiles...
Creating qgisconfig.py...
Done
It seems to be some problem parsing SIP files.
I have tried compiling a fresh svn in a different partition (to rule out
permission issues) and the result is different:
[ 66%] Generating core/Makefile, gui/Makefile
Done
[ 66%] Generating core/core.so
make[3]: g++: program not found
make[3]: *** [sipcorecmodule.o] Error 127
make[2]: *** [python/core/core.so] Error 2
make[1]: *** [python/CMakeFiles/python.dir/all] Error 2
make: *** [all] Error 2
I have seen cmake_cxx_compiler is different between the two machines I'm
working on. The one I can compile without errors uses /usr/bin/c++ and
the one with problems uses /usr/bin/g++-4.2, so I guess the problem can
come from this. I'll test tomorrow and comment the result.
Regards
Carlos
