[Qgis-developer] Re: composer redesign branch
Steven Bell botsnlinux at gmail.com
Fri Mar 7 09:53:30 EST 2008
Just to clarify, QGraphicsScene by itself doesn't have any particular
units.  The composer treats scene units as millimeters, but I don't think
there's anything special about millimeters in particular.
I'm a little confused as to why you wouldn't put the units in QgsSymbol.  I
see it as an attribute just like size or color.  In theory, we might want a
uniqueValueRenderer which renders different objects with different scale
types.  This seems harder to do if a higher-level class is doing the
scaling.
Steven
On Fri, Mar 7, 2008 at 2:46 AM, Marco Hugentobler <
marco.hugentobler at karto.baug.ethz.ch> wrote:
> Hi Steven,
> Many thanks for pointing this out. I was not aware that QgsGraphicsScene
> always has mm units.
> It would be a possibility that QGIS main map also switches to mm units. In
> this case QgsMapCanvasMap would determine the scale factor to transform
> pixel
> to mm and configure a QgsMapRenderContext containing this factor. I think
> it
> is not necessary that QgsSymbol knows its units. Higher level classes that
> configure the rendering context could do this and just pass the scale
> factor.
> The other way round would be that QGIS main canvas still has pixel units
> and
> print composer queries dpi of the map image and scales its widths and
> sizes
> to achieve wysiwyg. In my opinion, the global mm approach seems more
> general.
> Regards,
> Marco
> Am Donnerstag 06 März 2008 01:08:46 schrieb Steven Bell:
> > After thinking and looking at the code a little, I definitely didn't
> > explain that very well...
> > As you know, what you see in the main editing canvas is not always what
> you
> > get in the composer.  Likewise,what you see when using the cache preview
> in
> > the composer is not what you get when you render.
> > The root of the problem is that QGIS does all of its drawing in canvas
> > units, so when you switch canvases, you change how things look.  The map
> > composer uses millimeters - one QGraphicsScene unit is one mm.
> > Printers and PDF output both work with millimeters this way.  If I make
> a
> > QGraphicsRectItem with a size of 10mm square, it will come out 10mm
> square.
> > If the pen width is 1 scene unit (and isn't scaled), it will come out 1
> mm
> > wide.
> > Note that when the composer map cache pixmap is drawn, the sizes are all
> in
> > pixels again.  Thus, as the resolution of the cache image changes, the
> line
> > widths and symbol sizes all change.  This has caused a lot of confusion,
> > because although the rendered preview matches the rendered output, the
> > cached preview does not.
> > I'm not completely clear on what the DPI setting in the composer
> actually
> > does when doing a vector output such as SVG or Postscript.  Changing
> that
> > setting doesn't seem to affect them, but the vector output code does
> > reference it.  I think the SVG generator needs to know something about
> the
> > size/dpi so that rasterizers/renderers can render them properly.
> > What I did in the composer redesign branch was add an enum, mScaleType,
> > which tells the renderer what units the size is in.  The renderer sets a
> > size scale, which is dependent on the scale type, size, and current mupp
> > (map units per pixel).  Also, rather than setting a pointer to a pixmap,
> it
> > sets a pointer to a symbol renderer which will always render the symbol
> > with a size of 1.  QgsVectorLayer's drawFeature( ) method scales the
> > painter by the size scale and calls the symbolRenderer's render( )
> method.
> > Since this appears to be much slower than the current code, we probably
> > need to do some context-dependent caching.
> > In the rendering context, we would need to include some information
> about
> > whether we were rendering in screen units or paper units.  Perhaps more
> > correctly, we would like to know the output DPI, which will be one
> > (system-dependent) thing for the editing canvas, 25.4 for the composer
> > canvas, and some variable for the composer map cache.  Because of the
> way
> > the physical output is handled, I don't think we need to know or care
> what
> > the printer's DPI is.
> > This should enable the removal of the symbol/line width/text scale
> options
> > in the composer.  This also allows us to use the QgsMapRender class to
> > render the map, rather than having a bunch of almost-duplicate code.
>  The
> > code currently in composer_redesign uses QgsMapRender, but I haven't
> taken
> > the time to remove the scale boxes in the map control pane.
> > Let me know if this still isn't clear.  I haven't completely sorted it
> all
> > out, either. :-)
> > Steven
> > On Wed, Mar 5, 2008 at 4:09 AM, Marco Hugentobler <
> > > Hi Steven,
> > > > I would remove symbolScale and widthScale in favor of defining the
> > > widths
> > > > in terms of concrete units, whether pixels, millimeters, or map
> units.
> > > It would be good for me if you could explain this idea in more detail
> as
> > > I'm
> > > still not sure my understanding is correct.
> > > Do you mean that QgsSymbol should have its own pen width and stroke
> > > width? They would be specified e.g. in mm instead of pixels and when
> the
> > > symbol is
> > > applied, transformed to pixels according to the ouput device dpi?
> > > The idea that i had was to just work on pixel level with one
> scalefactor
> > > (mResolutionRatio). So if e.g. a printer has a resolution of screen
> dpi *
> > > 2,
> > > then mResolutionRatio would be 2 and all the width values for QPen,
> > > QBrush and also width/height for images would be scaled by factor 2.
> > > Caching pixmaps
> > > would only be alloud if mResolutionRatio is 1.
> > > I think that would be doable without many code changes. But it is not
> as
> > > generic and clean as working with real units (e.g. mm) in the qgis
> core.
> > > Regards,
> > > Marco
> > > Am Dienstag 04 März 2008 17:26:08 schrieb Steven Bell:
> > > > > So my suggestion is to have the rendering context somehow like
> this:
> > > > > class QgsMapRenderContext
> > > > >        QgsMapToPixel mMapToPixel;
> > > > >        QgsCoordinateTransform mCoordTransform;
> > > > >        QgsRect mExtent;
> > > > >        bool drawEditingInformation;
> > > > >        bool mRenderingStopped;
> > > > >        double mResolutionRatio;
> > > > > The resolution ratio is usually 1, except when drawing to a
> different
> > > > > paint
> > > > > device (like QPrinter). I hope it will allow to consider for
> > > > > different line
> > > > > width / symbol sizes on these output devices.
> > > > >From what I understand, QgsMapToPixel basically holds the
> information
> > > that
> > > > mResolutionRatio would contain.
> > > > Martin already mentioned this, but the rendering context needs to
> have
> > > some
> > > > way to tell the renderer whether to use maximum-resolution vector
> ouput
> > > or
> > > > cached pixmaps.  I would also add something about what the output
> units
> > > > are, whether pixels or millimeters.  Both of the above might be done
> > > > together with an "are we printing to ps/pdf/svg" bool.
> > > widths
> units.
> > > > This is what I have attempted to do in the current composer_redesign
> > > code.
> > > > One of the major problems is that printed millimeters are treated as
> > > > the same as screen pixels, rather than a separate but similar type
> of
> > > > measurement.
> > > > I hope this makes sense.  Let me know if I need to clarify anything.
> > > > Steven
> > > Dr. Marco Hugentobler
> > > Institute of Cartography
> > > ETH Zurich
> > > Technical Advisor QGIS Project Steering Committee
> ETH Zurich
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080307/0a4f9967/attachment-0001.html
