[Qgis-developer] rendering GRASS rasters broken in UTF-8 locale
Maciej Sieczka tutey at o2.pl
Tue May 6 13:33:39 EDT 2008
Hi
I'm currently using QGIS 0.10.0 + SVN r8401 on Debian tetsing x86, QT
4.4.0 rc1 in pl_PL.utf8 locale.
Any GRASS raster (even as small as 50x50 cells) which has a colortable,
freezes QGIS. QGIS last debug words, before pressing OK in the "Add
GRASS raster" dialog, are attached in a txt file.
Also, when I load a GRASS raster *without* a colortable it renders OK
(ie. all-grey, as one would expect since it has no coloratable
assigned), but when I try reducing the window size QGIS crashes, saying:
Warning 1: GRASS fatal error: region for current mapset is invalid
line 16: <e-w resol3: 29.98442368>
run "g.region"
When I start QGIS in C locale (eg. from a terminal after "export
LC_ALL=C") neither of these problems take place - GRASS rasters with
colortable are rendered OK and I can stretch/reduce the window as I like
without a crash. What's wrong?
Maciek
plugin URI: /home/grassdata/spearfish60/PERMANENT/cellhd/test
Add new raster layer
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsmaplayer.cpp: 52: (QgsMapLayer) QgsMapLayer::QgsMapLayer - lyrname is 'test'
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsmaplayer.cpp: 58: (QgsMapLayer) QgsMapLayer::QgsMapLayer - layerName is 'test'
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrastershader.cpp: 26: (QgsRasterShader) QgsRasterShader::QgsRasterShader called
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrastershaderfunction.cpp: 25: (QgsRasterShaderFunction) QgsRasterShaderFunction::QgsRasterShaderFunction called
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsmaplayer.cpp: 98: (setLayerName) QgsMapLayer::setLayerName: new name is 'test'
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 727: (lastModified) QgsRasterLayer::lastModified: /home/grassdata/spearfish60/PERMANENT/cellhd/test
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 789: (lastModified) last modified = wt. maj 6 18:00:28 2008
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3970: (buildRasterPyramidList) Building initial pyramid list
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 2
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 1073741824
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 1073741824
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 4
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 536870912
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 536870912
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 8
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 268435456
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 268435456
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 16
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 134217728
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 134217728
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 32
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 67108864
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 67108864
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 64
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 33554432
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 33554432
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 128
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 16777216
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 16777216
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 256
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 8388608
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 8388608
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 512
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 4194304
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 4194304
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 1024
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 2097152
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 2097152
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 2048
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 1048576
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 1048576
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 4096
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 524288
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 524288
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 8192
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 262144
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 262144
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 16384
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 131072
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 131072
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 32768
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 65536
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 65536
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 65536
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 32768
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 32768
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 131072
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 16384
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 16384
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 262144
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 8192
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 8192
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 524288
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 4096
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 4096
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 1048576
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 2048
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 2048
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 2097152
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 1024
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 1024
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 4194304
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 512
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 512
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 8388608
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 256
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 256
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 16777216
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 128
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 128
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3980: (buildRasterPyramidList), Pyramid: 33554432
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3981: (buildRasterPyramidList), xDim: 64
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3982: (buildRasterPyramidList), yDim: 64
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 506: (readFile) Raster initial SRS
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1102: (debugPrint) ***SpatialRefSystem***
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1103: (debugPrint) * Valid : false
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1104: (debugPrint) * SrsId : -1239064168
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1105: (debugPrint) * Proj4 :
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1106: (debugPrint) * Desc. :
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 252: (createFromWkt) QgsSpatialRefSys::createFromWkt(QString theWkt) using: PROJCS["UTM Zone 13, Northern Hemisphere",GEOGCS["clark66",DATUM["North_American_Datum_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-105],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["meter",1]]
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 362: (createFromProj4) QgsSpatialRefSys::createFromProj4 wholetext match on name failed, trying proj4string match
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 448: (getRecord) QgsSpatialRefSys::getRecord...running query: select * from tbl_srs where parameters='+proj=utm +zone=13 +ellps=clrk66 +datum=NAD27 +units=m +no_defs'
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1076: (openDb) QgsSpatialRefSys::openDb path = /usr/local/qgis/share/qgis/resources/srs.db
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 470: (getRecord) QgsSpatialRefSys::getRecord...trying system srs.db
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 525: (getRecord) QgsSpatialRefSys::getRecord retrieved:  select * from tbl_srs where parameters='+proj=utm +zone=13 +ellps=clrk66 +datum=NAD27 +units=m +no_defs'
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 367: (createFromProj4) QgsSpatialRefSys::createFromProj4 proj4string match search for srsid returned srsid: 1379
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 182: (loadFromDb) load SRS from /usr/local/qgis/share/qgis/resources/srs.db where srs_id is 1379
Warning: No valid projection. Unable to set map units.
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 511: (readFile) --------------------------------------------------------------------------------------
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 512: (readFile) QgsRasterLayer::readFile --- using wkt
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 513: (readFile) --------------------------------------------------------------------------------------
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 522: (readFile) Raster determined to have the following SRS
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1103: (debugPrint) * Valid : true
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1104: (debugPrint) * SrsId : 1379
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1105: (debugPrint) * Proj4 : +proj=utm +zone=13 +ellps=clrk66 +datum=NAD27 +units=m +no_defs
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsspatialrefsys.cpp: 1106: (debugPrint) * Desc. : NAD27 / UTM zone 13N
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 528: (readFile) Layer registry has 0layers
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3544: (getMetadata) dataset has no metadata
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 3571: (getMetadata) band 1 has no categories
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgscolortable.cpp: 40: (QgsColorTable) QgsColorTable::QgsColorTable()
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgsrasterlayer.cpp: 4051: (readColorTable) QgsRasterLayer::readColorTable()
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/raster/qgscolortable.cpp: 74: (clear) QgsColorTable::clear() called
