Fwd: Re: [Qgis-developer] Patch to Remove Qt3 Dependencies
Tom Elwertowski
telwertowski at comcast.net
Wed May 7 02:46:18 EDT 2008
Hi Marco,
I merged your revision and submitted the patch. checkSelectionChanges also needed the revision for deselection.
Tom
Marco Hugentobler wrote:
> Hi Tom,
> I think I found the reason for the problem with the ctrl - key. Considering
> all selection ranges in QgsAttributeTable::handleChangedSelections solves the
> problem:
> void QgsAttributeTable::handleChangedSelections()
> if (lockKeyPressed == false)
> //clear the list and evaluate the last selection
> emit selectionRemoved(false);
> QList<QTableWidgetSelectionRange> selectedItemRanges = selectedRanges();
> QList<QTableWidgetSelectionRange>::const_iterator range_it =
> selectedItemRanges.constBegin();
> for(; range_it != selectedItemRanges.constEnd(); ++range_it)
> for (int index = range_it->topRow(); index <= range_it->bottomRow();
> index++)
> emit selected(item(index, 0)->text().toInt(), false);
> emit repaintRequested();
> Once you changed this, please commit the patch to svn.
> Regards,
> Marco
> ---------- Weitergeleitete Nachricht ----------
> Betreff: Re: [Qgis-developer] Patch to Remove Qt3 Dependencies
> Datum: Freitag 02 Mai 2008
> Von: Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch>
> An: qgis-developer at lists.osgeo.org
> Hi Tom,
> I did a bit of testing. In general, things work fine. One problem I
> encountered is that if multiple entries are selected in the attribute table
> with holding the ctrl key down, the corresponsing map features are not
> selected in map view. It works correctly with the shift key.
> Regards,
> Marco
> Am Freitag 25 April 2008 04:43:54 schrieb Tom Elwertowski:
>> Hello all,
>> Here is a patch which removes use of Qt3 routines for all of QGIS except
>> the GRASS plugin:
>> http://telwertowski.home.comcast.net/qgisqt4_r8378.diff
>> Please test it and send comments. After resolving any issues, I would like
>> to submit it to svn trunk.
>> The GRASS plugin, which probably contains about half of the Qt3
>> dependencies, will be done later. The patch was done to build with the
>> Qt/Mac/64bit alpha1 release; Qt3 features are not being ported to
>> Mac/64bit.
>> Three categories of changes have be made:
>> 1. Remove use of qt3support library (Q3 classes).
>> 2. Remove use of qt3 compatibility routines in qt4 classes.
>> 3. Remove automatic cast of QString to char*.
>> Classes and places with non-trivial changes are:
>> Q3Table to QtableWidget (qgsattributeactiondialog, qgsattributetable,
>> qgsmeasure) Q3ListView to QTreeWidget (qgsbookmarks,
>> qgsrasterlayerproperties, qgsgeomtypedialog, qgsserversourceselect) Q3Dict
>> to QHash (qgsprojectproperty)
>> Q3Process to QProcess (qgsgpsplugin)
>> The most complex change involved handling selections in the item view
>> classes (tables, trees and lists) so this should be tested the most.
>> In spite of its name, QTreeWidget also handles multicolumn lists which are
>> not trees; just set rootIsDecoated to false. Qt4 QListWidget is for lists
>> with one column and no header.
>> Qt4 has two classes for each item view: QTable/Tree/ListWidget and
>> QTable/Tree/ListView. The Widget classes contain a backing store and the
>> View classes don't. The Widget classes correspond more closely to the Q3
>> classes.
>> qgsattributetable, which can take a while to load large tables, should
>> probably be rewritten as a QTableView with an QAbstractTableModel subclass
>> to pull individual cells directly for the provider as needed. It has been
>> ported as a QTableWidget to keep the port straightforward and not introduce
>> additional refactoring into this edit.
>> Removing automatic casts of QString to char* also uncovered some odd code.
>> Defining QT_NO_CAST_TO_ASCII will produce a compile error whenever an
>> implicit QString cast occurs. Based on these two examples, this macro
>> serves as 'lint' for QStrings.
>> QString str; delete str; // compiles due to cast of str.
>> tr("abc" + def + tr("ghi")) // ought to be tr("abc") + def + tr("ghi")
>> In most cases, I have used toUtf8() to eliminate implicit casts. If a file
>> already used toAscii(), toLatin1() or toLocal8Bit(), I also used it to keep
>> the file consistent. Implicit casts have also been removed from the GRASS
>> plugin so that QT_NO_CAST_TO_ASCII can be defined for all future builds.
>> The patch has been tested using Qt4.2, 4.3 and 4.4RC1 as well as
>> Qt4.4-Cocoa-alpha1.
>> Tom
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
