Fwd: Re: [Qgis-developer] Patch to Remove Qt3 Dependencies
Tim Sutton
tim at linfiniti.com
Wed May 7 12:22:33 EDT 2008
Hi Tom
Just a bit of feedback to say that I built under msvc with your patch.
Based on my limited basic testing, all seems ok on that platform, but
I didnt go much beyond opening a couple of files and panning & zooming
around etc.
Regards
Tim
2008/5/7 Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch>:
> Thanks a lot!
> Additionally I found (and commited) that clearing all existing selections in
> handleChangedSelections() is always necessary. Because in QTableWidget, it is
> now also possible to deselect rows while holding the ctrl key.
> Regards,
> Marco
> Am Mittwoch 07 Mai 2008 08:46:18 schrieb Tom Elwertowski:
> > Hi Marco,
> > I merged your revision and submitted the patch. checkSelectionChanges also
> > needed the revision for deselection.
> > Tom
> > Marco Hugentobler wrote:
> > > Hi Tom,
> > > I think I found the reason for the problem with the ctrl - key.
> > > Considering all selection ranges in
> > > QgsAttributeTable::handleChangedSelections solves the problem:
> > > void QgsAttributeTable::handleChangedSelections()
> > > if (lockKeyPressed == false)
> > > //clear the list and evaluate the last selection
> > > emit selectionRemoved(false);
> > > QList<QTableWidgetSelectionRange> selectedItemRanges =
> > > selectedRanges(); QList<QTableWidgetSelectionRange>::const_iterator
> > > range_it =
> > > selectedItemRanges.constBegin();
> > > for(; range_it != selectedItemRanges.constEnd(); ++range_it)
> > > for (int index = range_it->topRow(); index <=
> > > range_it->bottomRow(); index++)
> > > emit selected(item(index, 0)->text().toInt(), false);
> > > emit repaintRequested();
> > > Once you changed this, please commit the patch to svn.
> > > Regards,
> > > Marco
> > > ---------- Weitergeleitete Nachricht ----------
> > > Betreff: Re: [Qgis-developer] Patch to Remove Qt3 Dependencies
> > > Datum: Freitag 02 Mai 2008
> > > Von: Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch>
> > > An: qgis-developer at lists.osgeo.org
> > > Hi Tom,
> > > I did a bit of testing. In general, things work fine. One problem I
> > > encountered is that if multiple entries are selected in the attribute
> > > table with holding the ctrl key down, the corresponsing map features are
> > > not selected in map view. It works correctly with the shift key.
> > > Regards,
> > > Marco
> > > Am Freitag 25 April 2008 04:43:54 schrieb Tom Elwertowski:
> > >> Hello all,
> > >> Here is a patch which removes use of Qt3 routines for all of QGIS except
> > >> the GRASS plugin:
> > >> http://telwertowski.home.comcast.net/qgisqt4_r8378.diff
> > >> Please test it and send comments. After resolving any issues, I would
> > >> like to submit it to svn trunk.
> > >> The GRASS plugin, which probably contains about half of the Qt3
> > >> dependencies, will be done later. The patch was done to build with the
> > >> Qt/Mac/64bit alpha1 release; Qt3 features are not being ported to
> > >> Mac/64bit.
> > >> Three categories of changes have be made:
> > >> 1. Remove use of qt3support library (Q3 classes).
> > >> 2. Remove use of qt3 compatibility routines in qt4 classes.
> > >> 3. Remove automatic cast of QString to char*.
> > >> Classes and places with non-trivial changes are:
> > >> Q3Table to QtableWidget (qgsattributeactiondialog, qgsattributetable,
> > >> qgsmeasure) Q3ListView to QTreeWidget (qgsbookmarks,
> > >> qgsrasterlayerproperties, qgsgeomtypedialog, qgsserversourceselect)
> > >> Q3Dict to QHash (qgsprojectproperty)
> > >> Q3Process to QProcess (qgsgpsplugin)
> > >> The most complex change involved handling selections in the item view
> > >> classes (tables, trees and lists) so this should be tested the most.
> > >> In spite of its name, QTreeWidget also handles multicolumn lists which
> > >> are not trees; just set rootIsDecoated to false. Qt4 QListWidget is for
> > >> lists with one column and no header.
> > >> Qt4 has two classes for each item view: QTable/Tree/ListWidget and
> > >> QTable/Tree/ListView. The Widget classes contain a backing store and the
> > >> View classes don't. The Widget classes correspond more closely to the Q3
> > >> classes.
> > >> qgsattributetable, which can take a while to load large tables, should
> > >> probably be rewritten as a QTableView with an QAbstractTableModel
> > >> subclass to pull individual cells directly for the provider as needed.
> > >> It has been ported as a QTableWidget to keep the port straightforward
> > >> and not introduce additional refactoring into this edit.
> > >> Removing automatic casts of QString to char* also uncovered some odd
> > >> code. Defining QT_NO_CAST_TO_ASCII will produce a compile error whenever
> > >> an implicit QString cast occurs. Based on these two examples, this macro
> > >> serves as 'lint' for QStrings.
> > >> QString str; delete str; // compiles due to cast of str.
> > >> tr("abc" + def + tr("ghi")) // ought to be tr("abc") + def + tr("ghi")
> > >> In most cases, I have used toUtf8() to eliminate implicit casts. If a
> > >> file already used toAscii(), toLatin1() or toLocal8Bit(), I also used it
> > >> to keep the file consistent. Implicit casts have also been removed from
> > >> the GRASS plugin so that QT_NO_CAST_TO_ASCII can be defined for all
> > >> future builds.
> > >> The patch has been tested using Qt4.2, 4.3 and 4.4RC1 as well as
> > >> Qt4.4-Cocoa-alpha1.
> > >> Tom
> > >> _______________________________________________
> > >> Qgis-developer mailing list
> > >> Qgis-developer at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Institute of Cartography
> ETH Zurich
> Technical Advisor QGIS Project Steering Committee
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
